Home » Modeling » EMF » [CDO / Net4j] DB connection keep-alive failed Exceptions
[CDO / Net4j] DB connection keep-alive failed Exceptions [message #626190] Wed, 22 September 2010 08:40
Since some days I get inside the log from my CDO server, that it lost
the connection to the database.
Both are installed on the same PC, and he get back his connection, but
it is interessed why he get this exceptions.
Im run with the latest stable release CDO 3.0 with DBStore an MySQL Backend.
It is a known bug or problem?
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:21:31.803
!MESSAGE DB connection keep-alive failed
!STACK 0
com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionE xception: No
operations allowed after connection closed.Connection was implicitly
closed due to underlying exception/error:
** BEGIN NESTED EXCEPTION **
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException
MESSAGE: Communications link failure
Last packet sent to the server was 0 ms ago.
STACKTRACE:
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications
link failure
at sun.reflect.GeneratedConstructorAccessor20.newInstance(Unkno wn Source)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
com.mysql.jdbc.SQLError.createCommunicationsException(SQLErr or.java:1074)
at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3009)
at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:2895)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3438)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1951)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2101)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:25 48)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:24 77)
at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java :1422)
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$Conne ctionKeepAliveTask.run(DBStoreAccessor.java:912)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
Caused by: java.io.EOFException: Can not read response from server.
Expected to read 4 bytes, read 0 bytes before connection was
unexpectedly lost.
at com.mysql.jdbc.MysqlIO.readFully(MysqlIO.java:2455)
at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:2906)
... 10 more
** END NESTED EXCEPTION **
at sun.reflect.GeneratedConstructorAccessor26.newInstance(Unkno wn Source)
at com.mysql.jdbc.Util.getInstance(Util.java:381)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:984 )
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956 )
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:926 )
at com.mysql.jdbc.ConnectionImpl.checkClosed(ConnectionImpl.jav a:1115)
at com.mysql.jdbc.ConnectionImpl.createStatement(ConnectionImpl .java:2392)
at com.mysql.jdbc.ConnectionImpl.createStatement(ConnectionImpl .java:2374)
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$Conne ctionKeepAliveTask.run(DBStoreAccessor.java:911)
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:23:22.571
!STACK 0
Last packet sent to the server was 1 ms ago.
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:29:42.254
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:31:00.893
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:31:30.953
!STACK 0
STACKTRACE:
link failure
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:37:51.186
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:45:47.367
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:53:34.599
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
!ENTRY org.eclipse.emf.cdo.server.db 4 0 2010-09-22 13:55:29.587
!STACK 0
STACKTRACE:
link failure
unexpectedly lost.
... 10 more
Previous Topic:Adding a custom property in the properties view
Next Topic:[CDO/Net4j] how to use PostgreSQL driver support?
Current Time: Sun Oct 26 04:26:00 EDT 2025
Powered by FUDForum. Page generated in 0.03567 seconds
