Home » Modeling » M2T (model-to-text transformation) » [xtend] bidrectional references not set with two ecore models
[xtend] bidrectional references not set with two ecore models [message #625843] Wed, 22 September 2010 06:36 Go to next message
Hello
I have two ecore models where one extends from the other.
I am trying to set a bidirectional reference between two elements with xtend, which works fine if I would be using only one ecore model.
PPP and AAA are elements of model Base
PPP references AAA
BBB is an element of model Extended
BBB extends from AAA
In xtend the following code
let bbb = new BBB :
bbb.setPpp(new PPP)
creates an error message
The value of type 'org.eclipse.emf.ecore.impl.EClassImpl@48edb5 (name: PPP) (instanceClassName: null) (abstract: false, interface: false)' must be of type 'org.eclipse.emf.ecore.impl.EClassImpl@1049d3 (name: PPP) (instanceClassName: null) (abstract: false, interface: false)'
Any help would be appreciated
Richard
Ecore models attached
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Base"
    nsURI="http:///Base.ecore" nsPrefix="Base">
  <eClassifiers xsi:type="ecore:EClass" name="AAA">
    <eStructuralFeatures xsi:type="ecore:EReference" name="ppp" ordered="false" unique="false"
        eType="#//PPP" eOpposite="#//PPP/aaa"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" ordered="false" lowerBound="1"
        eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="PPP">
    <eStructuralFeatures xsi:type="ecore:EReference" name="aaa" ordered="false" unique="false"
        upperBound="-1" eType="#//AAA" containment="true" eOpposite="#//AAA/ppp"/>
  </eClassifiers>
</ecore:EPackage>
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Extended"
    nsURI="http:///Extended.ecore" nsPrefix="Extended">
  <eClassifiers xsi:type="ecore:EClass" name="BBB" eSuperTypes="Base.ecore#//AAA"/>
</ecore:EPackage>
Re: [xtend] bidrectional references not set with two ecore models [message #626001 is a reply to message #625843] Wed, 22 September 2010 07:21 Go to previous messageGo to next message
Hello Richard,
i cannot reproduce this using this workflow and extension:
<workflow>
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
		<registerEcoreFile value="src/metamodel/base.ecore" />
		<registerEcoreFile value="src/metamodel/extended.ecore" />
	</bean>
	<component class="org.eclipse.xtend.XtendComponent">
		<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel" />
		<invoke value="template::test::getThePPP()" />
		<outputSlot value="model" />
	</component>
	<component class="org.eclipse.emf.mwe.utils.Writer">
		<uri value="test.xmi" />
		<modelSlot value="model" />
	</component>
</workflow>
import Extended;
Base::PPP getThePPP() :
let bbb = new BBB :
bbb.setPpp(new Base::PPP) ->
bbb.ppp;
~Christian
Re: [xtend] bidrectional references not set with two ecore models [message #626213 is a reply to message #625843] Wed, 22 September 2010 08:48 Go to previous messageGo to next message
Thanks a lot Christian
It was the workflow definition. The registering of ecore files did the trick.
I thought it was also possible to achieve the same result with multiple beans.
<bean id="mmExtended"
	class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
	<metaModelFile value="Extended.ecore"/>
</bean>
<bean id="mmBase"
	<metaModelFile value="Base.ecore"/>
</bean>
	<metaModel idRef="mmExtended"/>
	<metaModel idRef="mmBase"/>
</component>
Is there a possible solution with this kind of setup?
[Updated on: Wed, 22 September 2010 08:48] by Moderator
Re: [xtend] bidrectional references not set with two ecore models [message #626236 is a reply to message #626213] Wed, 22 September 2010 09:02 Go to previous message
i think this kind of setup is not possible with dynamic emf.
~Christian
Previous Topic:[Acceleo] Problem by passing null to a template
Next Topic:[xtend] problems with uml2 type adaption when migrating
Current Time: Sat Oct 25 03:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.05956 seconds
