Home » Archived » Eclipse Communications Framework (ECF) » Pydev + ECF Using docshare
Pydev + ECF Using docshare [message #625152] Tue, 09 March 2010 20:47 Go to next message
Hi all, I'm trying to hook up Pydev with docshare and I was linked to by the friendly people at the irc to http://www.eclipse.org/forums/index.php?t=msg&th=161379& amp;start=0& and I have tried multiple configurations editing the plugin.xml within the docshare.jar to no avail.
Running latest Galileo and ECF and Pydev as of 3-8-10
Ubuntu 9.10 32Bit
Using a local ECF Generic Server
the XML entry is as follows:
<extension point="org.eclipse.ui.menus">
<menuContribution locationURI="popup:org.python.pydev.editor.PythonEditor.EditorContext ">
<dynamic class=" org.eclipse.ecf.docshare.menu.DocShareRosterMenuContribution Item "
id="org.eclipse.ecf.editorshare.pydev.dynamic1">
</dynamic>
</menuContribution>
</extension>
<extension
<menuContribution locationURI="popup:#PyEditContext">
id="org.eclipse.ecf.editorshare.pydev.dynamic2">
</dynamic>
</menuContribution>
</extension>
Any advice is greatly appreicated
On another problem, I cannot Synchronize files across the ECF Generic Server.. not a major issue as its across a network.
Re: Pydev + ECF Using docshare [message #625153 is a reply to message #625152] Thu, 11 March 2010 17:11 Go to previous message
Hi xcdarkmagician,
I can only think that perhaps the locationURI is not right for the pydev
editor class. The space at the end of this certainly looks incorrect to me:
<stuff deleted>
> <menuContribution
And the spaces in this class name are definitely not right.
> <dynamic class="
> </dynamic>
> </menuContribution>
> </extension>
The class name below is also not right...and the popup:#PyEditContext
looks suspect to me (it could be right, but I just don't know what the
Python Editor's context id is).
> <extension
> <dynamic class="
> </dynamic>
> </menuContribution>
> </extension>
Scott
Previous Topic:r-osgi, File-based discovery
Next Topic:Pydev + ECF Using docshare
Current Time: Sat Nov 08 22:29:49 EST 2025
Powered by FUDForum. Page generated in 0.03656 seconds
