Home » Modeling » TMF (Xtext) » [XText] unknown behavior
Re: [XText] unknown behavior [message #62919 is a reply to message #62917] |
Thu, 23 July 2009 11:19 |
Michael Burkhardt Messages: 64 Registered: July 2009 |
Member |
--------------000804090503040200020903
Hi Sebastian,
sorry, but the error occures with "ISO-8859-1", too. See Log in attachment.
This error occures with the package
http://download.itemis.com/distros/eclipse-SDK-3.5-xtext-0.7 .1-linux-gtk-x86_64.tar.gz
Ciao, Micha
--- Original-Nachricht ---
Absender: Sebastian Zarnekow
Datum: 23.07.2009 12:15
> Hi Michael,
> this seems to be a problem with your encoding.
> Is there any entry in the error log?
> Which version of Xtext do you use?
> What's your workspace encoding?
> Please try to change it to ISO-8859-1 as a workaround.
> Hope that helps,
> Sebastian
name="log"
Content-Disposition: inline;
filename="log"
!SESSION 2009-07-14 09:29:30.969 -----------------------------------------------
eclipse.buildId=I20090611-1540
java.version=1.6.0_13
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.p2.repository 2 0 2009-07-14 09:35:23.517
!MESSAGE Server returned lastModified <= 0 for http://subclipse.tigris.org/update_1.4.x/content.xml
!SESSION 2009-07-14 09:36:40.616 -----------------------------------------------
!ENTRY org.eclipse.equinox.p2.repository 2 0 2009-07-14 09:38:41.316
!ENTRY org.eclipse.equinox.p2.ui 2 0 2009-07-14 09:38:55.328
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.ui 2 10001 2009-07-14 09:38:55.328
!MESSAGE Your original request has been modified.
!SUBENTRY 2 org.eclipse.equinox.p2.ui 2 10005 2009-07-14 09:38:55.328
!MESSAGE "Subclipse - Required" will be ignored because it is already installed.
!MESSAGE "Subversion Client Adapter - Required" will be ignored because it is already installed.
!MESSAGE "Subversion Native Library Adapter (JavaHL) - Strongly Recommended" will be ignored because it is already installed.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 2 10001 2009-07-14 09:38:55.329
!SUBENTRY 2 org.eclipse.equinox.p2.ui 2 10005 2009-07-14 09:38:55.329
!ENTRY org.eclipse.equinox.p2.ui 2 0 2009-07-14 09:38:55.371
!SUBENTRY 1 org.eclipse.equinox.p2.ui 2 10001 2009-07-14 09:38:55.371
!SUBENTRY 2 org.eclipse.equinox.p2.ui 2 10005 2009-07-14 09:38:55.371
!SESSION 2009-07-15 09:17:57.686 -----------------------------------------------
eclipse.buildId=M20080221-1800
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.core.resources 2 10035 2009-07-15 09:17:58.821
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ant.core 4 1 2009-07-15 09:52:09.614
!MESSAGE PermGen space
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$000(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at org.eclipse.ant.internal.core.AntClassLoader.findClass(AntCl assLoader.java:54)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at org.apache.tools.ant.Project.<clinit>(Project.java:131)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:503)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:377)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .runScript(FeatureExportOperation.java:327)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .doExport(FeatureExportOperation.java:218)
at org.eclipse.pde.internal.core.exports.FeatureBasedExportOper ation.run(FeatureBasedExportOperation.java:45)
at org.eclipse.pde.internal.ui.build.FeatureExportJob.run(Featu reExportJob.java:59)
!ENTRY org.eclipse.core.jobs 4 2 2009-07-15 09:52:10.864
!MESSAGE An internal error occurred during: "Export Plug-ins".
!STACK 0
at org.eclipse.ant.core.AntRunner.getInternalAntRunner(AntRunne r.java:397)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:322)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .cleanup(FeatureExportOperation.java:579)
at org.eclipse.pde.internal.core.exports.FeatureBasedExportOper ation.run(FeatureBasedExportOperation.java:55)
!ENTRY org.eclipse.ui 4 0 2009-07-15 09:52:12.077
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2009-07-15 09:52:12.687
!SESSION 2009-07-15 09:52:50.335 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2009-07-15 09:52:51.485
!SESSION 2009-07-16 10:59:21.146 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2009-07-16 11:50:01.210
!MESSAGE Invalid preference page path: Cache
!ENTRY org.eclipse.ui 4 4 2009-07-16 11:50:01.225
!MESSAGE Invalid preference page path: Icon Style
!SESSION 2009-07-23 11:52:26.380 -----------------------------------------------
java.version=1.6.0_14
Command-line arguments: -data /home/mib/workspaces/dummy_workspace -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.ui 4 0 2009-07-23 11:52:31.390
!MESSAGE Unable to create editor ID org.eclipse.pde.ui.featureEditor: No editor descriptor for id org.eclipse.pde.ui.featureEditor
!STACK 1
org.eclipse.ui.PartInitException: No editor descriptor for id org.eclipse.pde.ui.featureEditor
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:598)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3468)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3115)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!SUBENTRY 1 org.eclipse.ui 4 0 2009-07-23 11:52:31.391
!MESSAGE No editor descriptor for id org.eclipse.pde.ui.featureEditor
!ENTRY org.eclipse.ui 2 2 2009-07-23 11:52:31.554
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@514ade37 from part: org.eclipse.ui.internal.ErrorEditorPart@514ade37
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
!ENTRY org.eclipse.xtext.ui.core 4 0 2009-07-23 11:53:31.509
!MESSAGE org.eclipse.xtext.ui.core.util.EclipseResourceUtil - org.eclipse.core.runtime.CoreException: Problems encountered while setting project description.
!ENTRY org.eclipse.jdt.core 4 4 2009-07-23 11:53:31.806
!MESSAGE JavaBuilder handling CoreException while building: org.xtext.example.language.mydsl
!STACK 1
Java Model Exception: Java Model Status [org.xtext.example.language.mydsl does not exist]
at org.eclipse.jdt.internal.core.JavaElement.newNotPresentExcep tion(JavaElement.java:492)
at org.eclipse.jdt.internal.core.JavaModelManager.getPerProject InfoCheckExistence(JavaModelManager.java:2062)
at org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo( JavaProject.java:1815)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1858)
at org.eclipse.jdt.internal.core.JavaProject.computeExpandedCla sspath(JavaProject.java:469)
at org.eclipse.jdt.internal.core.JavaProject.getExpandedClasspa th(JavaProject.java:1480)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.comput eClasspathLocations(NameEnvironment.java:93)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.<init >(NameEnvironment.java:41)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.initialize Builder(JavaBuilder.java:603)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:167)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2009-07-23 11:53:31.807
!MESSAGE org.xtext.example.language.mydsl does not exist
!ENTRY org.eclipse.jdt.core 4 4 2009-07-23 13:15:27.951
!STACK 1
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2009-07-23 13:15:27.952
!ENTRY org.eclipse.xtext.ui.core 4 0 2009-07-23 13:15:51.132
!ENTRY org.eclipse.jdt.core 4 4 2009-07-23 13:15:51.303
!STACK 1
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2009-07-23 13:15:51.304
--------------000804090503040200020903--
Re: [XText] unknown behavior [message #62922 is a reply to message #62921] |
Thu, 23 July 2009 12:47 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Micha,
please use the release update site to update Xtext to version 0.7.1:
http://download.eclipse.org/modeling/tmf/updates/
Seems there was only an interim build for the 0.7.1 thus the milestone
site was not updated.
As far as I know most components of oAW 4.3 have been superseded by
Eclipse projects (Xpand, MWE, Xtext). That's why it is not recommended
to use all oAW plugins and the Galileo plugins in the same installation.
Please open a bug and attach the list of installed plugins and
configuration settings if the problem persists.
Hope that helps,
Sebastian
Am 23.07.2009 14:03 Uhr, schrieb Michael Burkhardt:
> OK, I was wrong. I want to integrate XText in our projects and started
> another Eclipse installation. This installation used the XText version
> from
> http://download.eclipse.org/modeling/tmf/updates/milestones/ site.xml,
> means, version 0.7.0RC5. That means, it is not version 0.7.1 I've done
> my tests with :(
> But I need an installation of TMF Xtext 0.7.1 with Eclipse update site
> (site.xml), because XText is not the only Eclipse Plugin I need for my
> work.
> Is anything known about side effects with oAW-4.3.0?
> Ciao, Micha
>> Hi Michael,
>> Hope that helps,
>> Sebastian
Re: [XText] unknown behavior [message #62942 is a reply to message #62926] |
Thu, 23 July 2009 16:56 |
Hi Michael,
the MWE help is available with the 0.7.1 release, I guess it was missing
in 0.7.0.
Are you talking about the the Generate<MyDsl>.mwe?
The class org.eclipse.xtext.generator.Generator exposes properties like
srcGenPath and srcPath which could be set to /src/main/whatever/you/like.
Hope that helps,
Sebastian
Am 23.07.2009 16:03 Uhr, schrieb Michael Burkhardt:
> do you have any documentation found for MWE?
> (http://www.eclipse.org/modeling/emft/?project=mwe)
> I need properties or debug mode or anything like this, because I need to
> change my source folder from "{$project}/src" to "{$project}/src/main/java"
> Ciao
> Datum: 23.07.2009 14:47
>> Hi Micha,
>> Hope that helps,
>> Sebastian
Current Time: Fri Apr 26 17:15:21 GMT 2024
Powered by FUDForum. Page generated in 0.02749 seconds
