Re: ECF Twitter Connection Error [message #624670 is a reply to message #624669] |
Thu, 01 January 2009 22:09 |
Holger Staudacher Messages: 166 Registered: July 2009 |
Hi Scott,
it works great now. Thank you.
Holger
On 2009-01-01 18:55:10 +0100, Scott Lewis <slewis@composent.com> said:
> Hi Holger,
> I've discovered that the version of twitter 4j we were previously using
> (twitter4j 1.1.2) had a bug that caused twitter.verifyCredentials to
> always fail.
> http://groups.google.com/group/twitter4j/browse_thread/threa d/1b825c088faae4e7
This
> caused both of us to fail to authenticate.
> I've updated the code on ecf1.osuosl.org to twitter4j 1.1.3, and now
> it's able to connect properly.
> Note you can send status updates by using the UI, or automated/without
> UI using the IChatManager container adapter.
> The ECF presence API messaging is not yet fully implemented (e.g.
> replys), but I will work on it further (the provider) over the next few
> days (Jan 1-3).
> Thanks and happy tweeting.
> Scott
> Holger Staudacher wrote:
>> Hi all,
>> i tried to connect to twitter using Scotts ecf implementation for
>> twitter. But i got an error (see bellow). I debbugged the
>> TwitterContainer#connect method. All credentials are set correctly.
>> Here is my code:
>> IContainerFactory factory = ContainerFactory.getDefault();
>> IContainer container = factory.createContainer(
>> "ecf.twitter.twitter4j" );
>> IConnectContext context = getConnectionContext();
>> IIDFactory idFactory = IDFactory.getDefault();
>> ID targetId
>> = idFactory.createID( container.getConnectNamespace(), "USERNAME" );
>> container.connect( targetId, context );
>> The getConnectionContext Method creates an IConnectionContext and
>> implement the password for the given user in an ObjectCallbackHandler.
>> Any ideas? Thanks a lot for your help.
>> Regards, Holger
>> StackTrace:
>> Port 9278 already in use. This instance of R-OSGi is running on port 9279
>> org.eclipse.ecf.core.ContainerConnectException: Cound not authenticate
>> at
>> org.eclipse.ecf.provider.twitter.container.TwitterContainer. connect(TwitterContainer.java:203)
>> at
>> com.eclipesource.twitlyn.ContextUIStartup$1.taskActivated(Co ntextUIStartup.java:45)
>> at
>> org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.ac tivateTask(TaskActivityManager.java:413)
>> at
>> org.eclipse.mylyn.internal.tasks.ui.actions.TaskActivateActi on.run(TaskActivateAction.java:48)
>> at
>> org.eclipse.mylyn.internal.tasks.ui.views.TaskListCellModifi er.toggleTaskActivation(TaskListCellModifier.java:130)
>> at
>> org.eclipse.mylyn.internal.tasks.ui.views.TaskListView$9.mou seDown(TaskListView.java:929)
>> at
>> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:179)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1561)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1570)
>> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 360)
>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3482)
>> at org.eclipse.swt.widgets.Control.sendTrackEvents(Control.java :3024)
>> at org.eclipse.swt.widgets.Control.kEventControlTrack(Control.j ava:2104)
>> at org.eclipse.swt.widgets.Widget.controlProc(Widget.java:375)
>> at org.eclipse.swt.widgets.Display.controlProc(Display.java:862 )
>> at org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(Nati ve Method)
>> at org.eclipse.swt.widgets.Tree.kEventMouseDown(Tree.java:2599)
>> at org.eclipse.swt.widgets.Widget.mouseProc(Widget.java:1326)
>> at org.eclipse.swt.widgets.Display.mouseProc(Display.java:2929)
>> at org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(Na tive Method)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3051)
>> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
>> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>> at
>> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at
>> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>> at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>> at
>> java.lang.reflect.Method.invoke(Method.java:585)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
FUDForum. Page generated in 0.03655 seconds
