Re: Basic example??? - Eclipse Extension with TCP [message #628398 is a reply to message #624389] |
Thu, 23 September 2010 12:10 |
Ashokkumar Messages: 9 Registered: September 2010 Location: Chennai |
Hi Wayne,
I have given a little more detailed description below.
I have created a customised trace window(which is what i said as Trace jar) using RCP command template(Under Sample Menu creation). Which probably gets user inputs that has to be transferred to an external tool(Hardware Driver).
Monitor jar is a TCP monitor window(Java application with TCP configuration options) which is used to communicate with remote applications.
Please refer the below link for more information.
http://charithaka.blogspot.com/2008/08/how-to-use-tcpmon-ins ide-eclipse.html
I want to communicate with an external tool using TCP protocol. So i am looking for a way to interface my Trace window with Monitor window so that i can make use of the Monitor window's TCP options to communicate with the external tool(which also has support for TCP protocol).
Even i would be interested to know if i can directly add TCP interface to my Trace window so that i can communicate with the external tool without the help of Monitor window.
Please provide with a good Example or a link which explains eclipse extensions handling TCP protocol.
Looking for you response,
Thanks & Regards,
N. Ashokkumar.
[Updated on: Fri, 24 September 2010 06:11] Report message to a moderator
FUDForum. Page generated in 0.03223 seconds
