Home » Archived » Eclipse Communications Framework (ECF) » Communication between OSGi/Equinox - JMS/ActiveMQ
Re: Communication between OSGi/Equinox - JMS/ActiveMQ [message #624319 is a reply to message #624318] |
Thu, 30 October 2008 17:14 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Sebastian,
Sebastian Schneider wrote:
> Hey,
> have someone a example to implement the communication between
> OSGi/Equinox and JMS/ActiveMQ?
> I've already imported the package org.eclipse.ecf.provider.jms and
> activemq and found in the plug-in list the libaries for activemq
> (activemq3.1M5) but my example doesn't found the libs nor can these import.
In my own copy of the org.eclipse.ecf.provider.jms.activemq bundle I
have the various jars referenced on the bundle classpath inside the lib
directory. Are these not present for you inside your project? I
checked on the CVS repository and they also seem to be there.
> ActiveMQQueue queue = new ActiveMQQueue("Queue Test");
> ActiveMQConnectionFactory factory = new
> ActiveMQConnectionFactory("tcp://localhost:61616");
> ActiveMQConnection connection = (ActiveMQConnection)
> factory.createConnection();
> Session session = connection.createSession(false,
> Session.AUTO_ACKNOWLEDGE);
> MessageProducer producer = session.createProducer(queue);
> producer.send(session.createTextMessage("Test"));
> connection.close();
> Have you any idea?
> I need a short example for Queue(Sender/Receiver) and
> Topic(Publisher/Subscriber) in OSGi Framework.
> How I must to set up my OSGi bundle?
I'm not sure what is the problem you identify above (i.e. why the
activemq jars are not included).
As for the analog of what you have above within ECF...the parts dealing
strictly with JMS (i.e. not specific to ActiveMQ) are in:
org.eclipse.ecf.provider.jms.channel.AbstractJMSClientChanne l
which is in the org.eclipse.ecf.provider.jms bundle
and the JMS-specific bits are in the sub-class
org.eclipse.ecf.provider.jms.activemq.container.ActiveMQJMSC lientContainer.ActiveMQClientChannel
(which is an inner class inside ActiveMQJMSClientContainer) inside the
org.eclipse.ecf.provider.jms.activemq bundle.
The intention here is to separate the active-mq-specific stuff from the
JMS-generic stuff for session/topic setup, so that it is relatively easy
to create other providers based upon other JMS implementers. So, for
example, we have a Webshere JMS impl that is also based upon
org.eclipse.ecf.provider.jms. We would, of course, welcome other JMS
impls and if they want to use/reuse the org.eclipse.ecf.provider.jms to
create them that that is great.
Scott
Re: Communication between OSGi/Equinox - JMS/ActiveMQ [message #624326 is a reply to message #624319] |
Thu, 06 November 2008 13:15 |
Sebastian Schneider Messages: 18 Registered: July 2009 |
Hi Scott,
thank you for your reply and this tip.
I implements the following code [1] and it seems to work but I get the
error message [2] and I don't know how I send a message to the ActiveMQ
and receive it again.
---- [1]
try {
IContainer cont =
ContainerFactory.getDefault().createContainer("ecf.jms.activemq.tcp.client ");
ID targetID =
IDFactory.getDefault().createID(cont.getConnectNamespace(),
"tcp://localhost:61616/mytest");
cont.connect(targetID, null);
} catch (ContainerCreateException e) {
e.printStackTrace();
} catch (IDCreateException e) {
} catch (ContainerConnectException e) {
---- [2]
log4j:WARN No appenders could be found for logger
(org.activemq.transport.tcp.TcpTransportChannel).
log4j:WARN Please initialize the log4j system properly.
(org.activemq.ActiveMQConnection).
org.eclipse.ecf.core.ContainerConnectException: JMS Connect or Setup
Exception
at
org.eclipse.ecf.provider.jms.channel.AbstractJMSClientChanne l.connect(AbstractJMSClientChannel.java:69)
at
org.eclipse.ecf.provider.generic.ClientSOContainer.connect(C lientSOContainer.java:146)
at com.javaworld.sample.helloworld.Activator.start(Activator.ja va:51)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
org.eclipse.ecf.core.ContainerConnectException[0]: javax.jms.JMSException:
syncSendTimedOut: connection no longer OK
at
org.activemq.ActiveMQConnection.syncSendPacket(ActiveMQConne ction.java:1336)
at
org.activemq.ActiveMQConnection.syncSendPacket(ActiveMQConne ction.java:1306)
at org.activemq.ActiveMQSession.addConsumer(ActiveMQSession.jav a:1208)
at
org.activemq.ActiveMQMessageConsumer.<init>(ActiveMQMessageConsumer.java:143)
at org.activemq.ActiveMQSession.createConsumer(ActiveMQSession. java:622)
at org.eclipse.ecf.provider.jms.channel.JmsTopic.<init>(JmsTopic.java:31)
at
org.eclipse.ecf.provider.jms.channel.AbstractJMSChannel.setu pJMS(AbstractJMSChannel.java:175)
at
org.eclipse.ecf.provider.jms.channel.AbstractJMSClientChanne l.connect(AbstractJMSClientChannel.java:63)
at
at
at
at
at
at
at
at
at
at
at
at
at
I need really a simple example. I have too little know-how.
I forgot to import the other packages of ecf (CVS).
I didn't found this example of WebSphere. Where is it?
Thanks.
Sebastian
Re: Communication between OSGi/Equinox - JMS/ActiveMQ [message #624339 is a reply to message #624319] |
Thu, 20 November 2008 13:54 |
Hi Scott,
I read in your last post in the newsgroup that we need a broker, a ecf
generic jms server and than can connect the ecf generic client to this
server and activemq. Is it right?
I checked new out yesterday the "plugins/providers" from ecf1.osuosl.org
and found a different in org.eclipse.ecf.provider.jms.activemq/plugin.xml:
It missed the extenstion point of "containerFactory" with the name
"ecf.jms.activemq.tcp.server".
However, in my example code I will create and start the server [1] and
create later the client and try to send a message [2], but the problem is
to create the channel. I get only an error [3] in JMSTopic at the creating
of consumer and provider [4]. At [5] you will see the full stack.
Is it the right way to create the server and client in my example?
I tried also your ActiveMQJMSServer application with the "ActiveMQ JMS
Server.launch" configuration, but I get also an error with this [6] log
message.
My ActiveMQ "Broker" log following message:ERROR TransportConnector -
Could not accept connection : Wire format negotiation timeout: peer did
not send his wire format.
Have you an idea or tip where my problem is?
Thanks and best regards
Sebastian
~~~~ header
public static final String CLIENT_CONTAINER_NAME =
"ecf.jms.activemq.tcp.client";
public static final String SERVER_CONTAINER_NAME =
"ecf.jms.activemq.tcp.server";
public static final String TARGET_NAME = "tcp://localhost:61616/mytest";
//mytest should be the name of the topic?!
[1]
IContainer cont_srv =
ContainerFactory.getDefault().createContainer(SERVER_CONTAIN ER_NAME, new
Object[] {TARGET_NAME});
cont_srv.addListener(new IContainerListener() {
public void handleEvent(IContainerEvent event) {
if (event instanceof IContainerConnectedEvent)
serverConnectEvents.add(event);
if (event instanceof IContainerDisconnectedEvent)
serverDisconnectEvents.add(event);
[2]
IContainer cont =
ContainerFactory.getDefault().createContainer(CLIENT_CONTAIN ER_NAME);
ID targetID = IDFactory.getDefault().createID(cont.getConnectNamespace(),
TARGET_NAME);
IChannelContainerAdapter channelContainerAdapter =
(IChannelContainerAdapter)cont.getAdapter(IChannelContainerA dapter.class);
if(channelContainerAdapter != null){
ID channelID =
IDFactory.getDefault().createID(channelContainerAdapter.getC hannelNamespace(), "mytest");
IChannelListener channelListener = null;
IChannel channel = channelContainerAdapter.createChannel(channelID,
channelListener ,null);
channel.sendMessage("HELLO".getBytes());
[3] AbstractJMSChannel::setupJMS Line:175
[4]
public JmsTopic(Session session, String topic) throws JMSException {
destination = session.createTopic(topic); // destination is not null
consumer = session.createConsumer(destination); // I get here an error
producer = session.createProducer(destination);
[5]
org.eclipse.ecf.core.ContainerCreateException: Exception creating weblogic
server container
at
org.eclipse.ecf.internal.provider.jms.activemq.ActiveMQJMSSe rverContainerInstantiator.createInstance(ActiveMQJMSServerCo ntainerInstantiator.java:55)
at
org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:259)
at
org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:278)
at com.javaworld.sample.helloworld.Activator.start(Activator.ja va:72)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.ecf.core.ContainerCreateException[0]:
org.eclipse.ecf.core.util.ECFException: JMS Connect or Setup Exception
at
org.eclipse.ecf.provider.jms.channel.AbstractJMSChannel.setu pJMS(AbstractJMSChannel.java:185)
at
org.eclipse.ecf.provider.jms.channel.AbstractJMSServerChanne l. <init>(AbstractJMSServerChannel.java:33)
at
org.eclipse.ecf.provider.jms.activemq.container.ActiveMQServ erChannel. <init>(ActiveMQServerChannel.java:24)
at
org.eclipse.ecf.provider.jms.activemq.container.ActiveMQJMSS erverContainer.start(ActiveMQJMSServerContainer.java:38)
at
org.eclipse.ecf.internal.provider.jms.activemq.ActiveMQJMSSe rverContainerInstantiator.createInstance(ActiveMQJMSServerCo ntainerInstantiator.java:52)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.ecf.core.util.ECFException[0]: javax.jms.JMSException:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
[6]
!SESSION 2008-11-18 12:35:17.439
eclipse.buildId=unknown
java.version=1.6.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application
org.eclipse.ecf.provider.jms.ActiveMQServer
tcp://localhost:61616/exampleTopic
Command-line arguments: -application
org.eclipse.ecf.provider.jms.ActiveMQServer -data
C:\Texo_Tools\workspace_osgi/../runtime-ActiveMQJMSServer -dev
file:C:/Texo_Tools/workspace_osgi/.metadata/.plugins/org.ecl ipse.pde.core/ActiveMQ
JMS Server/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2008-11-18 12:35:28.712
!MESSAGE Application error
!STACK 1
at
at
at
at
at
org.eclipse.ecf.provider.jms.activemq.application.ActiveMQJM SServer.start(ActiveMQJMSServer.java:61)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2 0 2008-11-18 12:35:28.728
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-11-18 12:35:28.728
!MESSAGE Bundle
update@plugins/org.eclipse.ecf.ssl_1.0.1.v20081006-2232.jar was not
resolved.
!SUBENTRY 2 org.eclipse.ecf.ssl 2 0 2008-11-18 12:35:28.728
!MESSAGE Missing imported package org.eclipse.osgi.service.security_1.0.0.
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle
update@plugins/org.eclipse.ecf.ssl_1.0.1.v20081006-2232.jar [184] was not
resolved.
> Scott Lewis wrote:
> Hi Sebastian,
> > Hey,
> can these import.
> inside the lib
> > connection.close();
> > Have you any idea?
> parts dealing
> inside the
> stuff from the
> relatively easy
> Scott
Re: Communication between OSGi/Equinox - JMS/ActiveMQ [message #624340 is a reply to message #624339] |
Thu, 20 November 2008 13:55 |
Hi Scott,
Thanks for the tip with the server version. I have used the version 5.1
and changed it to 3.1.
So, your ActiveMQJMSServer works and connect to my ActiveMQ broker.
Adding new client: tcp://localhost:61616/mytest on transport:
TcpTransportChannel: Socket[addr=/127.0.0.1,port=2051,localport=61616]
> Scott Lewis wrote:
> No...actually it's the right way, but it's not enough. That
> is, prior
> to creating the channel on the client, it's necessary to create a
> corresponding channel (of the same name/id) on the server.
> The reason
> for this is that having a server container instance connected to the
> activemq broker is not enough...because ECF multiplexes multiple
> channels on top of the single connection.
> So, on the ecf generic server...upon startup you should have
> something
> like this:
> (get the server IContainer instance...via IContainerManager
> service or
> through some other means)
> pter.class);
> ID channelID =
> nnelNamespace(),"mytest");
> IChannelListener listener = <create listener to display
> received messages on the server>
> IChannel serverChannel =
> channelContainerAdapter.createChanne(channelID,listener,null );
> ...store server channel away for later usage for
> sending from server...
The container connect to the broker, but the channelContainerAdapter is
null.
I don't know what I must do with the IContainerManager to get a container?!
Is it right? I'm confused.
IContainer c = ContainerFactory.getDefault().createContainer();
IContainer container = containerManager.getContainer(c.getID());
I need a very simple and complete example for my implementation.
My context:
I try to implement a bundle with some monitoring application.
They listen as subscriber on a channel/topic and send also message
backward to another channel/topic.
At the moment I have only a Activator.java.
Sebastian
> but actually, I see that this error message(ultimately coming
> from activemq failure)
> might mean that the ECF generic server is failing to actually
> connect to the activemq broker...perhaps because of version
> incompatibilities.
> "ActiveMQ JMS Server.launch" configuration, but I get also an
> error with this [6] log message.
> TransportConnector - Could not accept connection : Wire
> format negotiation timeout: peer did not send his wire format.
> I suspect that there are two problems. The first (and hardest) is
> getting the ecf jms generic server (which is actually an activemq
> *client* when it connects to the activemq broker) to create a proper
> connection to the broker. I suspect that this:
> Which you got in response to the *ecf server/jms client* attempt to
> connect to the broker. My guess is that this is some version
> incompatibility across activemq versions (i.e. on the ecf generic
> server/jms client...which uses the activemq3.1m5) and the activemq
> broker that you are using (I don't know what version you are
> using). So
> we'll have to figure this out by getting some sort of version
> compatiblity (through same/similar activemq versions on broker and on
> ecf servers and clients). If you can let me know what version of the
> broker you are using, I will look into forward porting ECF generic
> server and clients to something compatible with that (i.e. 4.0 or etc)
> Then we have the missing code on the server (creating the
> channel as I
> described above). This will be relatively easy to fix once
> we get the
> connection problem worked out with activemq.
> So please let me know which version of activemq you are using for the
> broker, and I'll see about getting/updating the ecf activemq generic
> server and client with something compatible.
> Thanks much for patience. We'll work this out, but due to
> the length of
> time we have not updated activemq I think we'll need to deal
> with this
> buy forward porting things.
> Scott
Re: Communication between OSGi/Equinox - JMS/ActiveMQ [message #624341 is a reply to message #624340] |
Thu, 20 November 2008 16:28 |
Hi Sebastian,
> Hi Scott,
That's good to hear. I wouldn't mind moving over to use a more recent
ActiveMQ implementation...if this is something important to you please
open an enhancement request (with the version desired) so we can know
which version to focus on and can track (as well as communicate directly
with you and other interested parties about progress).
<stuff deleted>
> null.
Probably the easiest is to do:
IContainerManager manager = (IContainerManager)
ContainerFactory.getDefault();
IContainer [] containers = manager.getAllContainers();
(should return one container...i.e. the server container instance)
IChannelContainerAdapter adapter = (IChannelContainerAdapter)
containers[0].getAdapter(IChannelContainerAdapter.class);
But actually, I would recommend that you get the IContainerManager via
the OSGi service rather than via the static
ContainerFactory.getDefault() method (i.e. the IContainerManager is an
OSGi service, so you can get access to it via the ServiceTracker (see
here for an article about that, as it will be useful in other contexts:
http://www.eclipsezone.com/eclipse/forums/t90796.html
> My context:
I would/will be happy to produce a hello world example application, but
I need to travel soon and so will need a little time to do so.
Would you file an enhancement request to do this at
http://bugs.eclipse.org and it will allow me to not have the request get
lost given my traveling and such. In the mean time, the example code
for datashare can/could be helpful as well:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/bundles/org.eclipse.ecf.tests.datashare/src/org/eclipse/e cf/tests/datashare/?root=RT_Project
Scott
> Thanks
> Sebastian
>> but actually, I see that this error message(ultimately coming from
>> activemq failure)
>> might mean that the ECF generic server is failing to actually connect
>> to the activemq broker...perhaps because of version incompatibilities.
>> JMS Server.launch" configuration, but I get also an error with this
>> [6] log message.
>> - Could not accept connection : Wire format negotiation timeout: peer
>> broker that you are using (I don't know what version you are using).
>> So we'll have to figure this out by getting some sort of version
>> Then we have the missing code on the server (creating the channel as I
>> described above). This will be relatively easy to fix once we get the
>> Thanks much for patience. We'll work this out, but due to the length
>> of time we have not updated activemq I think we'll need to deal with
>> this buy forward porting things.
>> Scott
Current Time: Fri Apr 26 23:51:22 GMT 2024
Powered by FUDForum. Page generated in 0.03410 seconds
