| self contained equinox based eclipse installer [message #5630] |
Mon, 16 July 2007 18:29  |
Hello
I have created an eclipse installer.
The installer contains "eclipse classic - windows (140 MB)", but with
little modification it could easily be used on other platforms.
The installer would increase by 8 megabytes if it would contain the
necessary components to run on mac and linux, too.
With this installer, the download size could be reduced from 140 mb to
~90 mb.
The installer relies on Equinox, JFace and SWT.
TODO:
- install log in the unpacking process
- clear the temp folder on exit (osgi configuration folder, etc)
- IO & UI tweaks
- Code clean, refactor ;)
And the download:
http://gear.hu/blog/coffeshrub/eclipse33_installer_win32.jar
Ferenc Boldog
| Re: self contained equinox based eclipse installer [message #5647 is a reply to message #5642] |
Fri, 20 July 2007 18:18  |
Pascal Rapicault wrote:
> This is really interesting work.
Thx.
> Have you looked at creating an installer
> based on the equinox provisioning work?
not yet, but I am going to take a look into it.
> One could think of two approaches here, one much like what you are doing and
> the other where the initial download would just be the installer and the
> rest of the bytes would be downloaded from the web.
Yes, the updater/online installer version is more complicated (parsing
the site.xml, version checking), with the installer size staying small.
One of the possible solution, remove the unneeded classes form the plugins.
ie: current jface normal compressed (pack.gz) size: 281kb, and the
working (with my installer) stripped-down: 49kb.
Ferenc
| Re: self contained equinox based eclipse installer [message #575183 is a reply to message #5630] |
Wed, 18 July 2007 20:25  |
This is really interesting work. Have you looked at creating an installer
PaScaL
"Ferenc Boldog" <ferenc.boldog@gmail.com> wrote in message
news:f7gren$n0l$1@build.eclipse.org...
> Hello
> With this installer, the download size could be reduced from 140 mb to ~90
> mb.
> TODO:
> - IO & UI tweaks
> And the download:
> Ferenc Boldog
| Re: self contained equinox based eclipse installer [message #575195 is a reply to message #5642] |
Thx.
Ferenc
FUDForum. Page generated in 0.04059 seconds
