Re: ASM Dependency [message #624214 is a reply to message #624213] |
Wed, 15 October 2008 15:12 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Eric,
Eric Bresie wrote:
> Hey guys,
> I was investigating an issue that I thought to be related to the Ajax
> Framework Toolkit (AFT) (see
> http://www.eclipse.org/newsportal/article.php?id=633&gro up=eclipse.webtools.atf#633
> ) and saw a dependency error relating to ASM.
> The short description is during attempts to install some new plugins, I
> get the following:
> Cannot find a solution satisfying the following requirements
> Match[requiredCapability: org.eclipse.equinox.p2.iu/org.objectweb.asm/
> [2.2.3,2.2.3]].
> This made me think there was an ASM dependency issue of some type.
> Looking around, I find that ECF also has an ASM dependency.
> Can anyone provide any details on the usage of ASM in the context of
> ECF. Maybe this will help on the AFT issue.
ASM is used by the r-OSGi provider. Specifically, I believe it's used
to dynamically create a proxy.
The dependency is expressed in the ch.ethz.iks.r_osgi.remote bundle
manifest, and looks like this:
Import-Package: org.objectweb.asm;version="3.0.0",
The objectweb bundle that we use and deploy is the one from the Orbit
project (version 3.0.0).
It looks to me from the above that these other plugins require/are
limited to an older version (2.2.3) of ASM. This is probably wrong (in
that they should be using or at least supporting in metadata a more
recent version of ASM)
Scott
Re: ASM Dependency [message #624267 is a reply to message #624220] |
Thu, 16 October 2008 19:40 |
Hi Eric,
RE: how to find a specific dependency
In the PDE perspective, open the Plug-in Dependencies view.
Click on the 'Show State Status' icon to show the current state (i.e.
the runtime).
Then type in the filter the name of the org.objectweb bundle. The view
should then show you the bundle that is depending upon the objectweb bundle.
I don't why org.eclipse.equinox.p2.iu shows this dependency for you...in
the versions I'm using there doesn't seem to be any dep of
org.eclipse.equinox.p2.iu on org.objectweb.asm.
Scott
Eric Bresie wrote:
> Thanks for your help. This is very informative...Hope you don't mind a
> follow up...
>>> I get the following:
>>> [2.2.3,2.2.3]].
>> (in that they should be using or at least supporting in metadata a
>> more recent version of ASM)
> How is the easiest way to determine what plugin has this dependency?
> I found the "About Eclipse...Plugin Detail" helps a little bit, but I'm
> not completely sure how the dependency (what plugin depends on this
> plugin) for this can be determined.
> Or is it safe to say based on the description above, this it is related
> to the org.eclipse.equinox.p2.iu?
> Eric
FUDForum. Page generated in 0.03870 seconds
