Remote Services over ECF XMPP [message #624070] |
Thu, 25 September 2008 11:47  |
this should be really simple but we couldnt figure out how to do this.
We trying to get a Remote Service example over XMPP to run (our own simple example). The Service Interface simply
transfers Strings forward and backward and we try that with the client and server in separate JVMs and a local JABBER
server (Open Fire).
Client and Server connect successfully with different userids. The Server registers its Services over the ECF API.
However these remote services dont show up on the client as OSGi Services as Proxy. We have set the property on the
server to AUTOREGISTER_PROXY so it should do it. (I think)
I am also dont understand how it is supposed to work. I mean the client has "userid1" the server uses "userid2". Since
that is the information you pass in when you connect, how does "1" find the services from "2"? That was more obvious
when we tried R-OSGi and the generic Service protocol because there the client directly connected to the server. Here
with XMPP both connect to the XMPP server (broker) what the next (missing) step ?
Any hints is appreciated. We can post code if that is helpful but I think I am missing a fundamental point here.
We already looked through the samples and testcases in CVS. They are all not helpful for what we want because the
testcases there run in one JVM, which is maybe good for testing but not good for showcasing what is server and what is
client code.
I also think that the XMPP Testcases runs without an actually XMPP server simply by loopback magic within the JVM but I
am not sure about this.
thanks a lot
christian campo
Re: Remote Services over ECF XMPP [message #624072 is a reply to message #624070] |
Fri, 26 September 2008 20:26   |
Hi Christian,
Christian Campo wrote:
> simple example). The Service Interface simply transfers Strings forward
> and a local JABBER server (Open Fire).
> Server registers its Services over the ECF API. However these remote
> set the property on the server to AUTOREGISTER_PROXY so it should do it.
> (I think)
> has "userid1" the server uses "userid2". Since that is the information
> That was more obvious when we tried R-OSGi and the generic Service
> (missing) step ?
I suspect that you are missing this on service registration:
final Dictionary props = new Hashtable();
props.put(Constants.SERVICE_REGISTRATION_TARGETS,getClient(1 ).getConnectedID());
final IRemoteServiceRegistration result =
adapter.registerRemoteService(new String[] {serviceInterface}, service,
props);
Because their is no service discovery with XMPP, the registration
explicitly sets a registration target (the getClient(1).getConnectedID()
that is the service client (i.e. where the proxy gets created).
If there is/was a discovery mechanism this wouldn't be necessary, but
for xmpp (alone) it doesn't have discovery so something else is needed.
The code above is available in a test case for xmpp remote services.
That test case is here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.provider.xmpp/src/org/eclipse/ecf/t ests/provider/xmpp/remoteservice/?root=Technology_Project
> not helpful for what we want because the testcases there run in one JVM,
> server and what is client code.
If you have a test infrastructure that supports running tests in more
than one process we would/will be happy to use it and run test cases on
it. We don't have such a test harness, and the junit plugin tests don't
support that out of the Eclipse box anyway.
> server simply by loopback magic within the JVM but I am not sure about
> this.
No, the test case above takes two xmpp logins on (some) remote
server...via system properties. Many/most of the xmpp tests do this,
since we don't run an xmpp server in the test code but do run an xmpp
server at ecf.eclipse.org that we can/do use for testing.
But like I said, we would/will be happy to run tests in a multi-process
environment, but currently we don't have a) a test harness that supports
this; b) access to multiple machines to test in such a manner.
Scott
Re: Remote Services over ECF XMPP [message #624073 is a reply to message #624072] |
Sat, 27 September 2008 19:10   |
Thanks a lot.... One more question....
Scott Lewis schrieb:
> Hi Christian,
>> separate JVMs and a local JABBER server (Open Fire).
>> it. (I think)
>> client has "userid1" the server uses "userid2". Since that is the
>> services from "2"? That was more obvious when we tried R-OSGi and the
>> to the server. Here with XMPP both connect to the XMPP server (broker)
> props);
OK so here the server tells what client will see this service. What would be the way if the server is just the server
and knows its services and I'd like to register a proxy on the client either in OSGi oder ECF to access a known Service
on a known Service ID? So in the scenaria where multiple clients wants to access a service.
>> all not helpful for what we want because the testcases there run in
>> what is server and what is client code.
>> this.
> Scott
christian
Re: Remote Services over ECF XMPP [message #624075 is a reply to message #624073] |
Mon, 29 September 2008 19:19  |
Hi Christian,
<stuff deleted>
> would be the way if the server is just the server and knows its services
Yes. I've created an enhancement request to deal with this use case,
and I've begun implementation.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249061
Please add yourself to the bug if you are interested...it should be done
pretty quickly...and I would like to ask you to help test it obviously.
Scott
FUDForum. Page generated in 0.03331 seconds
