Re: List listener problem [message #62821 is a reply to message #62746] |
Sun, 25 November 2007 13:18 |
Christian Messages: 31 Registered: July 2009 |
Member |
Val,
Thanks for your answer. Do you think I should open a bug for this
version?Or realese version 1.1 will contain this bug fixed anyway?
Christian
Val ha scritto:
> Hi
> I have ran your example and indeed it did not work, but that on the
> 1.0.1 integration build.
> If u use release version 1.0 it works just fine.
> Also the demo application does not work fine regarding list selection,
> when using version 1.0.1
> Cheers,
> Val
> Christian wrote:
>> Hi,
>> i've added a Selection listener to a List; if i select some components
>> on the List, and invoking the method List.getSelection in the
>> implemented listener, it returns no items selected. Can be a bug?
>> here the code
>> list = new List(sectionClient2, SWT.MULTI | SWT.V_SCROLL | SWT.H_SCROLL
>> | SWT.BORDER);
>> list.add("item");
>> list.add("item2");
>> list.addListener(SWT.Selection,listener);
>> public final class MyListener implements Listener {
>> public void handleEvent(Event arg0) {
>> System.out.println(arg0);
>> String[] ele = list.getSelection();
>> for (int i = 0; i < ele.length; i++) {
>> System.out.println(ele[i]);
>> thx
>> Christian
Re: List listener problem [message #62853 is a reply to message #62821] |
Sun, 25 November 2007 14:32 |
Valer Roman Messages: 36 Registered: July 2009 |
Member |
yes I think u should open a bug report for that version. Also mention
that in the demo application the list selection does not work properly.
ciao,
Val
Christian wrote:
> Val,
> Christian
> Val ha scritto:
>> Hi
>> Cheers,
>> Val
>> Christian wrote:
>>> Hi,
>>> here the code
>>> | SWT.BORDER);
>>> list.add("item");
>>> list.add("item2");
>>> thx
>>> Christian
FUDForum. Page generated in 0.03257 seconds
