Home » Modeling » UML2 » Issues with Importing MagicDraw Files into a Simple Project
Issues with Importing MagicDraw Files into a Simple Project [message #622564] Mon, 25 June 2007 12:58
--------------000604030502050507070800
I am running MagicDraw 12.1 and on the Eclipse Side I have enclosed the
configuration file.
The problem:
I exported a large model from MagicDraw to EMF UML Format. The result
was a directory that had six files, all with the extension ".uml2". Of
the six files. four came from MagicDraw profiles, one is my model and
the last one is the profile that I am using with the model.
I then created a simple project. Created a "Model" folder and then
proceeded to do a "Import => FileSystem". I selected the directory
containing the MagicDraw files and then clicked ok.
The import created six model nodes in the package explorer, each with
I then tried to open one of the nodes with the "UML Editor".
Before the model was displayed in the Editor, a second set of nodes were
created in the browser. These nodes had the extension ".uml". I was
able to look at both kinds of nodes in the editor.
Now here is the interesting part. If I exit the workbench and then
restart it, the ".uml2" nodes can be opened up just fine with the UML
Editor. However, the ".uml" nodes result in an error. I included the
error log.
I tried to delete the ".uml" files but when I re-opened the ".uml2"
model, the ".uml" fields re-appeared.
Has anyone seen this problem before?
-David
========================== Configuration ========================
*** Date: Mon Jun 25 11:42:58 EDT 2007
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060629-1905
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
f50_78
-vm
C:\WINDOWS\SYSTEM32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1182785711987
eclipse.vm=C:\WINDOWS\SYSTEM32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\Program Files\Eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Eclipse\startup.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0
java.io.tmpdir=C:\DOCUME~1\DAVIDG~1\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\SYSTEM32;.;C:\WINDOWS\Sun\Java\ bin;C:\WINDOWS\system32;C:\WINDOWS;c:\MinGW\bin;C:\WINDOWS;C :\WINDOWS\SYSTEM32;C:\j2sdk1.4.2_08\bin;C:\MinGW\bin;C:\cygw in\bin; "C:\Program
Files\Zone Labs\ZoneAlarm\MailFrontier";C:\Program
Files\Subversion\bin;C:\Program Files\QuickTime\QTSystem\;c:\Cygnin\bin;
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0-b105
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0-b105
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAn
y
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Program
Files\Eclipse\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Program Files/Eclipse/configuration/
osgi.framework=file:/c:/Program
Files/Eclipse/plugins/org.eclipse.osgi_3.2.2.R32x_v20070118. jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/C:/Program Files/Eclipse/
osgi.instance.area=file:/C:/TestOutPluginDevelopment/
osgi.instance.area.default=file:/C:/Documents and Settings/David
Glaser/workspace/
osgi.logfile=C:\TestOutPluginDevelopment\.metadata\.log
osgi.manifest.cache=C:\Program
Files\Eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Program
Files\Eclipse\plugins\org.eclipse.platform_3.2.2.r322_v20070 117b\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Program Files\Eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0\lib\resources.jar;C:\Program
Files\Java\jre1.6.0\lib\rt.jar;C:\Program
Files\Java\jre1.6.0\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0\lib\jce.jar;C:\Program
Files\Java\jre1.6.0\lib\charsets.jar;C:\Program Files\Java\jre1.6.0\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\Program Files\Eclipse
user.home=C:\Documents and Settings\David Glaser
user.language=en
user.name=David Glaser
user.timezone=America/New_York
user.variant=
*** Features:
org.apache.batik (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik"
org.eclipse.emf (2.2.3.v200705141058) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.cdo (0.7.1.v200610271316) "CDO"
org.eclipse.emf.cdo.client (0.7.1.v200610271316) "CDO Client Framework"
org.eclipse.emf.cdo.dbgen (0.7.1.v200610271316) "CDO DBGen Framework"
org.eclipse.emf.cdo.doc (0.7.1.v200610271316) "CDO Documentation"
org.eclipse.emf.cdo.jdbc (0.7.1.v200610271316) "CDO JDBC Framework"
org.eclipse.emf.cdo.server (0.7.1.v200610271316) "CDO Server Framework"
org.eclipse.emf.cdo.source (0.7.1.v200610271316) "CDO Source"
org.eclipse.emf.codegen.jet.editor (0.7.2.v200701042200) "JET Editor"
org.eclipse.emf.codegen.jet.editor.doc (0.8.0.v200703030036) "Eclipse
Modeling Framework Technology JET Editor Documentation"
org.eclipse.emf.codegen.jet.editor.source (0.8.0.v200703030036) "Java
Emitter Templates (JET) Editor Developer Resources"
org.eclipse.emf.compare (0.7.0.v200706130300) "Model comparison Plug-in"
org.eclipse.emf.compare.doc (0.7.0.I200706130300) "Doc Plug-in for EMF
Comapre"
org.eclipse.emf.compare.source (0.7.0.v200706130300) "EMF Compare Source"
org.eclipse.emf.doc (2.2.2.v200705141058) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.2.1.v200705141058) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.2.1.v200705141058) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.2.1.v200705141058) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.examples (2.2.0.v200705141058) "Eclipse Modeling
Framework (EMF) Examples"
org.eclipse.emf.ocl (1.1.0.v200612211659) "Object Constraint Language
(OCL) 2.0"
org.eclipse.emf.query (1.0.1.v200702011850) "Eclipse Modeling Framework
Technology Query Framework"
org.eclipse.emf.query.ocl (1.0.1.v200702011850) "Eclipse Modeling
Framework Technology Query OCL"
org.eclipse.emf.source (2.2.3.v200705141058) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.teneo (0.8.0.v200704230019) "Teneo"
org.eclipse.emf.teneo.doc (0.8.0.v200704230019) "Teneo Documentation"
org.eclipse.emf.teneo.source (0.8.0.v200704230019) "Eclipse Modeling
Framework Technology (EMFT) Teneo Source"
org.eclipse.emf.transaction (1.1.0.v200702011903) "Eclipse Modeling
Framework Technology Transaction Core"
org.eclipse.emf.validation (1.1.0.v200702011853) "Eclipse Modeling
Framework Technology Model Validation Core"
org.eclipse.emf.workspace (1.1.0.v200702011903) "Eclipse Modeling
Framework Technology Workbench Core"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.gmf (1.0.3.v20070202-1200-gW3quizrSB1Fxqp) "Graphical
Modeling Framework"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.1.v20060815_M----6zXJJzKIRGVU) "Java EMF Model"
org.eclipse.net4j (0.7.1.v200610271244) "Net4j"
org.eclipse.net4j.doc (0.7.1.v200610271244) "Net4j Documentation"
org.eclipse.net4j.source (0.7.1.v200610271244) "Net4j Source"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project SDK"
org.eclipse.uml2 (2.0.2.v200610251409) "UML2"
org.eclipse.uml2.doc (2.0.2.v200610251409) "UML2 Documentation"
org.eclipse.uml2.examples (2.0.2.v200610251409) "UML2 Examples"
org.eclipse.uml2.examples.source (2.0.2.v200610251409) "UML2 Examples
Source"
org.eclipse.uml2.source (2.0.2.v200610251409) "UML2 Source"
org.eclipse.xsd (2.2.3.v200705141058) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.2.1.v200705141058) "XML Schema Infoset Model
(XSD) Programmers Guide"
org.eclipse.xsd.source (2.2.3.v200705141058) "XML Schema Infoset Model
(XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.0.0.200612060942) "SourceForge
LPG" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Resolved]
org.eclipse.emf (2.2.0.v200705141058) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.activities (2.2.0.v200705141058) "EMF Activities" [Resolved]
org.eclipse.emf.ant (2.2.0.v200705141058) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.cdo (0.7.1.v200610271316) "CDO" [Resolved]
[Resolved]
org.eclipse.emf.cdo.client.edit (0.7.1.v200610271316) "CDO Client Edit
Support" [Resolved]
org.eclipse.emf.cdo.client.ocl (0.7.1.v200610271316) "CDO Client OCL
Support" [Resolved]
org.eclipse.emf.cdo.core (0.7.1.v200610271316) "CDO Core Framework"
[Resolved]
[Resolved]
org.eclipse.emf.cdo.dbgen.ansi92 (0.7.1.v200610271316) "CDO DBGen Ansi
SQL92 Dialect" [Resolved]
org.eclipse.emf.cdo.dbgen.derby (0.7.1.v200610271316) "CDO DBGen DERBY
Dialect" [Resolved]
org.eclipse.emf.cdo.dbgen.edit (0.7.1.v200610271316) "CDO DBGen Edit
Support" [Resolved]
org.eclipse.emf.cdo.dbgen.editor (0.7.1.v200610271316) "CDO DBGen
Editor" [Resolved]
org.eclipse.emf.cdo.dbgen.hsqldb (0.7.1.v200610271316) "CDO DBGen HSQLDB
Dialect" [Resolved]
org.eclipse.emf.cdo.dbgen.mysql (0.7.1.v200610271316) "CDO DBGen MySQL
Dialect" [Resolved]
org.eclipse.emf.cdo.dbgen.oracle (0.7.1.v200610271316) "CDO DBGen Oracle
SQL Dialect" [Resolved]
org.eclipse.emf.cdo.doc (0.7.1.v200610271316) "CDO Documentation" [Resolved]
org.eclipse.emf.cdo.examples.client (0.7.1.v200610271316) "CDO Example
Client" [Resolved]
org.eclipse.emf.cdo.examples.library (0.7.1.v200610271316) "CDO Example
Library" [Resolved]
org.eclipse.emf.cdo.examples.library.ui (0.7.1.v200610271316) "CDO
Example Library UI" [Resolved]
org.eclipse.emf.cdo.examples.server (0.7.1.v200610271316) "CDO Example
Server" [Resolved]
org.eclipse.emf.cdo.examples.ui (0.7.1.v200610271316) "CDO Example User
Interface" [Resolved]
[Resolved]
org.eclipse.emf.cdo.jdbc.derby (0.7.1.v200610271316) "CDO JDBC DERBY
Driver" [Resolved]
org.eclipse.emf.cdo.jdbc.hsqldb (0.7.1.v200610271316) "CDO JDBC HSQLDB
Driver" [Resolved]
org.eclipse.emf.cdo.jdbc.mysql (0.7.1.v200610271316) "CDO JDBC MYSQL
Driver" [Resolved]
org.eclipse.emf.cdo.mapping (0.7.1.v200610271316) "CDO Mapping Model"
[Resolved]
org.eclipse.emf.cdo.mapping.edit (0.7.1.v200610271316) "CDO Mapping Edit
Support" [Resolved]
org.eclipse.emf.cdo.mapping.editor (0.7.1.v200610271316) "CDO Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.emf.cdo.source (0.7.1.v200610271316) "CDO Source" [Resolved]
org.eclipse.emf.cdo.tests (0.7.1.v200610271316) "CDO Tests" [Resolved]
org.eclipse.emf.cdo.utilities.migrator (0.7.1.v200610271316) "CDO
Migrator Utility" [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200705141058) "EMF Cheat Sheets"
[Resolved]
org.eclipse.emf.codegen (2.2.2.v200705141058) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200705141058) "EMF Ecore Code
Generation" [Active]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200705141058) "EMF Ecore Code
Generation UI" [Active]
[Resolved]
Modeling Framework Technology JET Editor Documentation" [Resolved]
org.eclipse.emf.codegen.jet.editor.examples.unitteststemplat es
(0.7.2.v200701042200) "pluginName" [Resolved]
Emitter Templates (JET) Editor Developer Resources" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200705141058) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200705141058) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200705141058) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.1.0.v200705141058) "CommonJ SDO" [Resolved]
[Resolved]
org.eclipse.emf.compare.diff (0.7.0.v200706130300) "Diff Model" [Resolved]
org.eclipse.emf.compare.diff.edit (0.7.0.v200706130300) "Diff Edit
Support" [Resolved]
Comapre" [Resolved]
org.eclipse.emf.compare.examples.diff.extension (0.7.0.I200706130300)
"Diff_extension Model" [Resolved]
org.eclipse.emf.compare.match (0.7.0.v200706130300) "Match Model" [Resolved]
Source" [Resolved]
org.eclipse.emf.compare.team.ui (0.7.0.v200706130300) "Compare Plugin
Team extensions" [Resolved]
org.eclipse.emf.compare.ui (0.7.0.v200706130300) "Ui Plug-in" [Resolved]
org.eclipse.emf.converter (2.2.1.v200705141058) "EMF Model Convert
Support" [Active]
(EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.2.3.v200705141058) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200705141058) "EMF Ecore Change
Model" [Active]
org.eclipse.emf.ecore.change.edit (2.2.0.v200705141058) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200705141058) "EMF Ecore Edit
Support" [Active]
org.eclipse.emf.ecore.editor (2.2.0.v200705141058) "Sample Ecore Editor"
[Resolved]
Objects (SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200705141058) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200705141058) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.3.v200705141058) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200705141058) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.2.3.v200705141058) "EMF Edit UI" [Active]
Framework (EMF) Examples" [Resolved]
org.eclipse.emf.examples.library (2.2.0.v200705141058) "Extended Library
Model" [Resolved]
org.eclipse.emf.examples.library.edit (2.2.0.v200705141058) "Extended
Library Edit" [Resolved]
org.eclipse.emf.examples.library.editor (2.2.0.v200705141058) "Extended
Library Editor" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200705141058) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.exporter.html (2.2.0.v200705141058) "HTML Exporter for
EMF models" [Resolved]
org.eclipse.emf.importer (2.2.2.v200705141058) "EMF Model Import
Support" [Active]
org.eclipse.emf.importer.ecore (2.2.0.v200705141058) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200705141058) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.2.3.v200705141058) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.java (2.2.0.v200705141058) "EMF Java" [Resolved]
org.eclipse.emf.java.edit (2.2.0.v200705141058) "EMF Java Edit" [Resolved]
org.eclipse.emf.java.editor (2.2.0.v200705141058) "EMF Java Editor"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200705141058) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200705141058) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200705141058) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200705141058) "Ecore to XML
Mapping" [Active]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200705141058) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200705141058) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200705141058) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200705141058) "XSD to
(OCL) 2.0" [Resolved]
Technology Query Framework" [Resolved]
Framework Technology Query OCL" [Resolved]
(EMF) Source" [Resolved]
org.eclipse.emf.teneo (0.8.0.v200704230019) "Teneo" [Resolved]
org.eclipse.emf.teneo.annotations (0.8.0.v200704230019) "Teneo
Annotations" [Resolved]
[Resolved]
org.eclipse.emf.teneo.eclipse (0.8.0.v200704230019) "Teneo Eclipse UI"
[Resolved]
org.eclipse.emf.teneo.hibernate (0.8.0.v200704230019) "Teneo Hibernate"
[Resolved]
org.eclipse.emf.teneo.hibernate.eclipse (0.8.0.v200704230019) "Teneo
Hibernate Eclipse UI" [Resolved]
org.eclipse.emf.teneo.hibernate.libraries (0.8.0.v200704230019) "Teneo
Hibernate Test Libraries Plug-in" [Resolved]
org.eclipse.emf.teneo.hibernate.mapper (0.8.0.v200704230019) "Teneo
Hibernate Mapper" [Resolved]
org.eclipse.emf.teneo.jpox (0.8.0.v200704230019) "Teneo JPOX" [Resolved]
org.eclipse.emf.teneo.jpox.eclipse (0.8.0.v200704230019) "Teneo JPOX
org.eclipse.emf.teneo.jpox.libraries (0.8.0.v200704230019) "Plugin.name"
[Resolved]
org.eclipse.emf.teneo.libraries (0.8.0.v200704230019) "Teneo Libraries"
[Resolved]
org.eclipse.emf.teneo.samples (0.8.0.v200704230019) "Teneo" [Resolved]
Framework Technology (EMFT) Teneo Source" [Resolved]
org.eclipse.emf.teneo.tutorial (0.8.0.v200704230019) "Teneo Tutorial
Code" [Resolved]
Framework Technology Transaction Core" [Resolved]
org.eclipse.emf.transaction.ui (1.0.1.v200702011903) "Eclipse Modeling
Framework Technology Transaction UI" [Resolved]
Framework Technology Model Validation Core" [Resolved]
org.eclipse.emf.validation.ocl (1.1.0.v200702011853) "Eclipse Modeling
Framework Technology Validation Support for OCL" [Installed]
org.eclipse.emf.validation.ui (1.0.1.v200702011853) "Eclipse Modeling
Framework Technology Validation UI" [Resolved]
org.eclipse.emf.validation.ui.ide (1.0.1.v200702011853) "Eclipse
Modeling Framework Technology Validation UI IDE" [Resolved]
Framework Technology Workbench Core" [Resolved]
org.eclipse.emf.workspace.ui (1.0.100.v200702011903) "Eclipse Modeling
Framework Technology Workbench UI" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved]
org.eclipse.gmf (1.0.0.v20060713-1700) "Graphical Modeling Framework"
[Resolved]
org.eclipse.gmf.bridge (1.0.1.v20060925-1700) "GMF Models Bridging
Plug-in" [Resolved]
org.eclipse.gmf.bridge.ui (1.0.1.v20060925-1700) "GMF Tooling UI" [Resolved]
org.eclipse.gmf.bridge.ui.dashboard (1.0.1.v20060925-1700) "GMF
Dashboard" [Resolved]
org.eclipse.gmf.codegen (1.0.2.v20070202-0200) "GMF GenModel and Code
Generation" [Resolved]
org.eclipse.gmf.codegen.edit (1.0.0.v20060713-1700) "GMF GenModel Edit
Support" [Resolved]
org.eclipse.gmf.codegen.ui (1.0.1.v20060919-0800) "GMF Code Generation
UI" [Resolved]
org.eclipse.gmf.common (1.0.1.v20060925-1700) "GMF Tooling Commons
Plug-in" [Resolved]
org.eclipse.gmf.doc.ui (1.0.0.v20060713-1700) "GMF Documentation
Cheatsheets" [Resolved]
org.eclipse.gmf.ecore.editor (1.0.1.v20060919-0800) "ECore Sample
Diagram Plugin" [Resolved]
org.eclipse.gmf.graphdef (1.0.1.v20060919-0800) "GMF Graphical
Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (1.0.2.v20061027-1200) "Graphical
Definition Code Generator" [Resolved]
org.eclipse.gmf.graphdef.codegen.ui (1.0.1.v20060925-1700) "Graphical
Definition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (1.0.1.v20060925-1700) "GMFGraph Edit
Support" [Resolved]
org.eclipse.gmf.map (1.0.0.v20060713-1700) "GMF Mapping Model" [Resolved]
org.eclipse.gmf.map.edit (1.0.0.v20060713-1700) "GMF Mapping Edit
Support" [Resolved]
org.eclipse.gmf.runtime.common.core (1.0.3.v20070209-1900) "GMF Common
Core" [Resolved]
org.eclipse.gmf.runtime.common.ui (1.0.2.v20061020-1000) "GMF Common UI"
[Resolved]
org.eclipse.gmf.runtime.common.ui.action (1.0.1.v20060810-1700) "GMF
Common UI Action" [Resolved]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20060925-1700) "GMF
Common UI Action IDE" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20060803-1200) "GMF
Printing" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20061012-1100)
"GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.3.v20070105-1200) "GMF
Common UI Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.action (1.0.3.v20070119-1200)
"GMF Common UI Action Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20060925-1700)
"GMF Common UI DND Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd.ide
(1.0.1.v20060925-1700) "GMF Common UI DND IDE Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.properties
(1.0.1.v20060919-0800) "GMF Common UI Properties Service Framework"
[Resolved]
org.eclipse.gmf.runtime.diagram.core (1.0.2.v20061027-1200) "GMF Diagram
Core" [Resolved]
org.eclipse.gmf.runtime.diagram.ui (1.0.3.v20070202-0200) "GMF Diagram
UI" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.3.v20070119-1200) "GMF
Diagram Actions" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20060919-0800) "GMF
Diagram Browse" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.1.v20060919-0800) "GMF
Geometric Shapes" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.3.v20070202-0200) "GMF
Diagram Printing" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing.render
(1.0.1.v20060919-0800) "GMF Diagram UI Printing Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.3.v20070202-0200)
"GMF Diagram UI Properties" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.3.v20061218-1500) "GMF
Diagram Providers" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.1.v20060919-0800)
"GMF Diagram Providers IDE" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.3.v20070202-0200) "GMF
Diagram UI Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor
(1.0.3.v20070111-0800) "GMF Diagram UI Resources Editor Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
(1.0.3.v20070105-1200) "GMF IDE Editor" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui (1.0.3.v20070202-0200) "GMF Draw2d
Additions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.1.v20061218-1500) "GMF
Draw2d Image Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.3.v20070105-1200) "GMF
Draw2d Image AWT based Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.1.v20060919-0800) "GMF
EMF Clipboard Support" [Resolved]
org.eclipse.gmf.runtime.emf.commands.core (1.0.3.v20070209-1900) "GMF
org.eclipse.gmf.runtime.emf.core (1.0.3.v20070105-1200) "GMF Modeling
Service Layer" [Resolved]
org.eclipse.gmf.runtime.emf.type.core (1.0.1.v20060919-0800) "GMF EMF
Type Core" [Resolved]
org.eclipse.gmf.runtime.emf.type.ui (1.0.1.v20060925-1700) "GMF EMF Type
UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui (1.0.1.v20060925-1700) "GMF MSL UI"
[Resolved]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20061012-1100) "GMF
EMF UI Properties Providers" [Resolved]
org.eclipse.gmf.runtime.gef.ui (1.0.1.v20060919-0800) "GMF GEF
org.eclipse.gmf.runtime.notation (1.0.1.v20060919-0800) "GMF Notation
Model Support" [Resolved]
org.eclipse.gmf.runtime.notation.edit (1.0.1.v20060925-1700) "GMF
Notation Edit Support" [Resolved]
org.eclipse.gmf.runtime.notation.providers (1.0.1.v20060925-1700) "GMF
Notation Metamodel" [Resolved]
org.eclipse.gmf.sdk (1.0.0.v20060713-1700) "Graphical Modeling Framework
SDK" [Resolved]
org.eclipse.gmf.tooldef (1.0.0.v20060713-1700) "GMF Tooling Model"
[Resolved]
org.eclipse.gmf.tooldef.edit (1.0.0.v20060713-1700) "GMF Tooling Edit
Support" [Resolved]
org.eclipse.gmf.validate (1.0.2.v20061027-1200) "GMF Validation" [Resolved]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Resolved]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.2.0.v20060918_M) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities"
[Resolved]
org.eclipse.jem.workbench (1.2.1.v20060918_M) "Java EMF Model Workbench
Support" [Resolved]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Resolved]
org.eclipse.net4j (0.7.1.v200610271244) "Net4j" [Resolved]
org.eclipse.net4j.core (0.7.1.v200610271244) "Net4j Core Framework"
[Resolved]
org.eclipse.net4j.doc (0.7.1.v200610271244) "Net4j Documentation" [Resolved]
org.eclipse.net4j.embedded (0.7.1.v200610271244) "Net4j Embedded
org.eclipse.net4j.examples.client (0.7.1.v200610271244) "Net4j Example
Client" [Resolved]
org.eclipse.net4j.examples.client.ui (0.7.1.v200610271244) "Net4j
Example Client UI" [Resolved]
org.eclipse.net4j.examples.mvc (0.7.1.v200610271244) "Net4j Example MVC
org.eclipse.net4j.examples.mvc.swt (0.7.1.v200610271244) "Net4j Example
MVC SWT Support" [Resolved]
org.eclipse.net4j.examples.prov (0.7.1.v200610271244) "Net4j Example
Provisioning Model" [Resolved]
org.eclipse.net4j.examples.prov.client (0.7.1.v200610271244) "Net4j
Example Provisioning Client" [Resolved]
org.eclipse.net4j.examples.prov.client.ui (0.7.1.v200610271244) "Net4j
Example Provisioning Client UI" [Resolved]
org.eclipse.net4j.examples.prov.edit (0.7.1.v200610271244) "Net4j
Example Provisioning Edit Support" [Resolved]
org.eclipse.net4j.examples.prov.editor (0.7.1.v200610271244) "Net4j
Example Provisioning Editor" [Resolved]
org.eclipse.net4j.examples.prov.server (0.7.1.v200610271244) "Net4j
Example Provisioning Server" [Resolved]
org.eclipse.net4j.examples.server (0.7.1.v200610271244) "Net4j Example
Server" [Resolved]
org.eclipse.net4j.socket (0.7.1.v200610271244) "Net4j Socket Framework"
[Resolved]
org.eclipse.net4j.source (0.7.1.v200610271244) "Net4j Source" [Resolved]
org.eclipse.net4j.spring (0.7.1.v200610271244) "Net4j Spring Framework"
[Resolved]
org.eclipse.net4j.spring.db (0.7.1.v200610271244) "Net4j Spring DB
org.eclipse.net4j.util (0.7.1.v200610271244) "Net4j Utilities" [Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Active]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.2.v3236) "Standard Widget Toolkit
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Resolved]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal
Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21
Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.uml2 (2.0.2.v200610251409) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.2.2.v200610251409) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.2.0.v200610251409) "UML2 Ecore Code
Generation UI" [Resolved]
org.eclipse.uml2.common (1.2.2.v200610251409) "UML2 Common" [Active]
org.eclipse.uml2.common.edit (1.2.0.v200610251409) "UML2 Common Edit
Support" [Active]
org.eclipse.uml2.doc (2.0.2.v200610251409) "UML2 Documentation" [Resolved]
org.eclipse.uml2.examples (2.0.2.v200610251409) "UML2 Examples" [Resolved]
Source" [Resolved]
org.eclipse.uml2.examples.uml.ui (2.0.1.v200610251409) "UML2 UML
Examples UI" [Resolved]
org.eclipse.uml2.source (2.0.2.v200610251409) "UML2 Source" [Resolved]
org.eclipse.uml2.uml (2.0.2.v200610251409) "UML2 UML Model" [Active]
org.eclipse.uml2.uml.ecore.exporter (2.0.0.v200610251409) "UML2 UML
Exporter for EMF" [Resolved]
org.eclipse.uml2.uml.ecore.importer (2.0.0.v200610251409) "UML2 UML
Importer for EMF" [Active]
org.eclipse.uml2.uml.edit (2.0.2.v200610251409) "UML2 UML Edit Support"
[Active]
org.eclipse.uml2.uml.editor (2.0.1.v200610251409) "UML2 UML Editor" [Active]
org.eclipse.uml2.uml.resources (2.0.2.v200610251409) "UML2 UML
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.2.R32x_v20061214) "Install/Update
Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Active]
[Resolved]
org.eclipse.xsd.cheatsheets (2.2.0.v200705141058) "XML Schema Infoset
Model (XSD) Cheat Sheets" [Resolved]
(XSD) Programmers Guide" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200705141058) "XML Schema
org.eclipse.xsd.ecore.importer (2.2.0.v200705141058) "XML Schema
Importer for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.1.v200705141058) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200705141058) "XML Schema Editor" [Resolved]
org.eclipse.xsd.example (2.1.0.v200705141058) "XML Schema Infoset Model
Example" [Resolved]
(XSD) Source" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
*** User Preferences:
#Mon Jun 25 11:43:00 EDT 2007
/instance/org.eclipse.help.ui/browser.maximized=true
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.pde.runtime/orderValue=-1
@org.eclipse.emf.converter=2.2.1.v200705141058
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.ui.ide/platformState=1182650562646
@org.eclipse.help.ui=3.2.0.v20060602
file_export_version=3.0
@org.eclipse.pde.core=3.2.1.v20060915-0800
@org.eclipse.jdt.ui=3.2.2.r322_v20070124
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.pde.core/platform_path=C\:\\Program Files\\Eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.ui.browser=3.2.0.v20060602
@org.eclipse.jdt.launching=3.2.2.r322_v20061114
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=C \:\\TestOutPluginDevelopment\\org.eclipse.uml2.uml.editor\\a bout.html|*|file\:/C\:/TestOutPluginDevelopment/org.eclipse. uml2.uml.editor/about.html|*|
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.2.3.v_686_R32x
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Tes tOutPluginDevelopment,C\:\\Documents
and Settings\\David Glaser\\workspace
/instance/org.eclipse.help.ui/browser.y=37
/instance/org.eclipse.help.ui/browser.x=30
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.pde.runtime/column4=203
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.pde.runtime/column3=292
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.pde.runtime/column2=300
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.pde.runtime=3.2.0.v20060605
@org.eclipse.core.resources=3.2.2.R32x_v20061218
@org.eclipse.ui=3.2.1.M20061108
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1182715607592 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1182715607592" name\="jre1.6.0" path\="C\:\\Program
Files\\Java\\jre1.6.0"/>\r\n</vmType>\r\n</vmSettings>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.editors=3.2.1.r321_v20060721
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.emf.converter/org.eclipse.emf.importer .ui.contribution.ModelImporterManager=org.eclipse.uml2.uml.e core.importer
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
*** Current Install Configuration:
Install configuration:
Last changed on Jun 23, 2007
Files/Eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.emf.codegen.jet.editor.doc, Version: 0.8.0.v200703030036
0.7.2.v200701042200
ID: org.eclipse.emf.codegen.jet.editor.sdk, Version: 1.0.0.v200701042200
ID: org.eclipse.emf.teneo.doc, Version: 0.8.0.v200704230019
ID: org.eclipse.emf.cdo.doc, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.query.ocl, Version: 1.0.1.v200702011850
ID: org.eclipse.emf.compare.examples, Version: 0.7.0.I200706130300
ID: org.eclipse.emf.workspace, Version: 1.1.0.v200702011903
ID: org.eclipse.emf.validation.ocl, Version: 1.1.0.v200702011853
ID: org.eclipse.uml2, Version: 2.0.2.v200610251409
ID: org.eclipse.emf.doc, Version: 2.2.2.v200705141058
ID: org.eclipse.sdk, Version: 3.2.2.r322_v20070212
ID: org.eclipse.emf.examples, Version: 2.2.0.v200705141058
ID: org.eclipse.emf.sdk, Version: 2.2.3.v200705141058
ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.2.1.v200705141058
ID: org.apache.batik, Version: 1.6.0.v20060613-1220
ID: org.eclipse.emf.transaction, Version: 1.1.0.v200702011903
ID: org.eclipse.emf.teneo.source, Version: 0.8.0.v200704230019
ID: org.eclipse.emf.source, Version: 2.2.3.v200705141058
ID: org.eclipse.emf, Version: 2.2.0.v200705141058
ID: org.eclipse.xsd, Version: 2.2.3.v200705141058
ID: org.eclipse.emf.cdo.utilities, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.ocl, Version: 1.1.0.v200612211659
ID: org.eclipse.emf.compare.source, Version: 0.7.0.v200706130300
ID: org.eclipse.uml2.examples, Version: 2.0.2.v200610251409
ID: org.eclipse.emf.validation, Version: 1.1.0.v200702011853
0.8.0.v200703030036
ID: org.eclipse.gmf, Version: 1.0.0.v20060713-1700
ID: org.eclipse.emf.cdo.dbgen, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.cdo.sdk, Version: 0.7.1.v200610271316
ID: org.eclipse.pde, Version: 3.2.1.v20060810-0800
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.2.1.v200705141058
ID: org.eclipse.emf.query, Version: 1.0.1.v200702011850
ID: org.eclipse.xsd.source, Version: 2.2.3.v200705141058
ID: org.eclipse.emf.ecore.sdo, Version: 2.2.1.v200705141058
ID: org.eclipse.jem, Version: 1.2.1.v20060918_M
ID: org.eclipse.emf.teneo.sdk, Version: 0.8.0.v200704230019
ID: org.eclipse.platform, Version: 3.2.2.r322_v20070117b
ID: org.eclipse.net4j.examples, Version: 0.7.1.v200610271244
ID: org.eclipse.emf.teneo.examples, Version: 0.8.0.v200704230019
ID: org.eclipse.emf.compare, Version: 0.7.0.v200706130300
ID: org.eclipse.uml2.source, Version: 2.0.2.v200610251409
ID: org.eclipse.net4j.doc, Version: 0.7.1.v200610271244
ID: org.eclipse.rcp.source, Version: 3.2.2.r322_v20070104-8pcviKVqd8J7C1U
ID: org.eclipse.net4j, Version: 0.7.1.v200610271244
ID: org.eclipse.emf.cdo.client, Version: 0.7.1.v200610271316
ID: org.eclipse.pde.source, Version: 3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
ID: org.eclipse.uml2.doc, Version: 2.0.2.v200610251409
ID: org.eclipse.emf.cdo.source, Version: 0.7.1.v200610271316
ID: org.eclipse.gef, Version: 3.2.2.v20070208
ID: org.eclipse.jdt.source, Version: 3.2.2.r322_v20070104-R4CR0Znkvtfjv9-
ID: org.eclipse.net4j.source, Version: 0.7.1.v200610271244
ID: org.eclipse.emf.cdo.server, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.teneo, Version: 0.8.0.v200704230019
ID: org.eclipse.emf.cdo.jdbc, Version: 0.7.1.v200610271316
ID: org.eclipse.rcp, Version: 3.2.0.v20060605
ID: org.eclipse.jdt, Version: 3.2.1.r321_v20060823
ID: org.eclipse.emf.compare.doc, Version: 0.7.0.I200706130300
ID: org.eclipse.emf.cdo, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.codegen.jet.editor, Version: 0.7.2.v200701042200
ID: org.eclipse.emf.cdo.examples, Version: 0.7.1.v200610271316
ID: org.eclipse.emf.compare.sdk, Version: 0.7.0.v200706130300
ID: org.eclipse.net4j.sdk, Version: 0.7.1.v200610271244
ID: org.eclipse.xsd.doc, Version: 2.2.1.v200705141058
ID: org.eclipse.uml2.examples.source, Version: 2.0.2.v200610251409
ID: org.eclipse.gmf.callisto, Version: 1.0.3.v20070202-1200
Configured plug-ins:
file:/C:/Program
Files/Eclipse/plugins/com.ibm.etools.emf.event_3.0.0.v200609 18_M.jar
file:/C:/Program Files/Eclipse/plugins/com.ibm.icu.source_3.4.5.20061213/
file:/C:/Program Files/Eclipse/plugins/com.ibm.icu_3.4.5.20061213.jar
file:/C:/Program Files/Eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/C:/Program
Files/Eclipse/plugins/net.sourceforge.lpg.lpgjavaruntime_1.0 .0.200612060942.jar
file:/C:/Program Files/Eclipse/plugins/org.apache.ant_1.6.5/
file:/C:/Program
Files/Eclipse/plugins/org.apache.batik_1.6.0.v20060613-1220/
file:/C:/Program
Files/Eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531 .jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.ant.ui_3.2.1.r321_v2006082 8.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.compare_3.2.1.M20060711.ja r
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.boot_3.1.100.v2006060 3.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060 605-1400.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20 060603.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.expressions_3.2.2.r32 2_v20070109a.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.filebuffers_3.2.1.r32 1_v20060721.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.filesystem.win32.x86_ 1.0.0.v20060603.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v200 60603.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.jobs_3.2.0.v20060603. jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.resources.compatibili ty_3.2.0.v20060603.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.resources.win32_3.2.0 .v20060603.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.resources_3.2.2.R32x_ v20061218.jar
file:/C:/Program
Files/Eclipse/plugins/org.eclipse.core.runtime.compatibility .auth_3.2.0.v20060601.jar
file:/C:/Program
Previous Topic:Issues with MagicDraw Models in New EMF Project
Next Topic:[Announce] MDT UML2 2.1.0 2.1RC4 is available
Current Time: Fri Sep 26 00:18:41 EDT 2025
Powered by FUDForum. Page generated in 0.03986 seconds
