Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] array as eattribute value
[EMF Compare] array as eattribute value [message #621995] |
Thu, 14 January 2010 10:24 |
--------------060308090502030902030609
I am using EMF compare to compare that conversion from xml to objects and back work correctly. My model (see attachment)
has a number of EAttributes which have an Array as value. I have to sets of eobjects, when I persist them to xml/xmi
then the two xmi's are exactly the same. But EMF Compare reports still many differences. It seems that the array values
are not compared on their content but on 'the same object'
I use this code to match and diff:
final Map<String, Object> options = new HashMap<String, Object>();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, Boolean.TRUE);
options.put(MatchOptions.OPTION_IGNORE_ID, Boolean.TRUE);
MatchModel match = MatchService.doResourceMatch(resource1,
resource2, Collections.<String, Object> emptyMap());
// Computing differences
DiffModel diff = DiffService.doDiff(match, false);
assertTrue(diff.getDifferences().isEmpty());
Attached you can find my ecore file and the 2 xml files (which are the same).
(other comparison on other models work fine)
Let me know if I missed something obvious! (or not ofcourse :-)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="types.ecore"
Content-Disposition: inline;
filename="types.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="types"
nsURI="http://www.eclipse.org/emf/texo/test/model//types" nsPrefix="types">
<eClassifiers xsi:type="ecore:EClass" name="SingleTypes">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="string" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
defaultValueLiteral="test"test"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="integer" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"
defaultValueLiteral="100"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="integerObject" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="long" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"
defaultValueLiteral="200"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="longObject" ordered="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELongObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="double" ordered="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDouble" defaultValueLiteral="100"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="doubleObject" ordered="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="float" ordered="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EFloat"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="floatObject" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EFloatObject"
defaultValueLiteral="10f"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="clazz" ordered="false">
<eGenericType eClassifier="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EJavaClass">
<eTypeArguments/>
</eGenericType>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="char" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EChar"
defaultValueLiteral="z"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="charObject" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ECharacterObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="byte" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EByte"
defaultValueLiteral="5"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="byteObject" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EByteObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="byteArray" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EByteArray"
defaultValueLiteral=""/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bigDecimal" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBigDecimal"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bigInteger" ordered="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBigInteger"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="enum" eType="#//TestEnum"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="date" ordered="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDate"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="stringArray" eType="#//StringArray"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="longArray" eType="#//LongArray"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nextEnum" eType="#//TestNextEnum"
defaultValueLiteral="Enum2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ManyTypes">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="string" upperBound="-1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString" defaultValueLiteral="test"test"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="integerObject" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="long" ordered="false" upperBound="-1"
upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDoubleObject"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="floatObject" upperBound="-1"
upperBound="-1">
<eTypeArguments/>
</eGenericType>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="charObject" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="byteObject" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="byteArray" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bigDecimal" upperBound="-1"
upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBigInteger"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="enum" upperBound="-1" eType="#//TestEnum"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="date" ordered="false" upperBound="-1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDate" defaultValueLiteral="test"test"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="stringArray" upperBound="-1"
eType="#//StringArray" defaultValueLiteral=""/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="longArray" upperBound="-1"
eType="#//LongArray" defaultValueLiteral=""/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="TestEnum">
<eLiterals name="Enum0" literal="Enum0"/>
<eLiterals name="Enum1" value="1" literal="Enum1"/>
<eLiterals name="Enum2" value="2" literal="Enum2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="LongArray" instanceClassName="long[]"/>
<eClassifiers xsi:type="ecore:EDataType" name="StringArray" instanceClassName="java.lang.String[]"/>
<eClassifiers xsi:type="ecore:EEnum" name="TestNextEnum">
</eClassifiers>
</ecore:EPackage>
name="xml2.xml"
filename="xml2.xml"
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:types="http://www.eclipse.org/emf/texo/test/model//types">
<types:ManyTypes>
<string>string1</string>
<string>string2</string>
<string>string3</string>
<string>string4</string>
<string>string5</string>
<integerObject>1</integerObject>
<integerObject>2</integerObject>
<integerObject>3</integerObject>
<integerObject>4</integerObject>
<integerObject>5</integerObject>
<long>1</long>
<long>2</long>
<long>3</long>
<long>4</long>
<long>5</long>
<doubleObject>0.1</doubleObject>
<doubleObject>0.2</doubleObject>
<doubleObject>0.30000000000000004</doubleObject>
<doubleObject>0.4</doubleObject>
<doubleObject>0.5</doubleObject>
<floatObject>0.1</floatObject>
<floatObject>0.2</floatObject>
<floatObject>0.3</floatObject>
<floatObject>0.4</floatObject>
<floatObject>0.5</floatObject>
<clazz xsi:nil="true"/>
<charObject>84</charObject>
<charObject>72</charObject>
<charObject>73</charObject>
<charObject>83</charObject>
<byteObject>0</byteObject>
<byteObject>1</byteObject>
<byteObject>2</byteObject>
<byteObject>3</byteObject>
<byteObject>4</byteObject>
<byteArray>00</byteArray>
<byteArray>01</byteArray>
<byteArray>02</byteArray>
<byteArray>03</byteArray>
<byteArray>04</byteArray>
<bigDecimal>0.1000000000000000055511151231257827021181583404541015625 </bigDecimal>
<bigDecimal>0.200000000000000011102230246251565404236316680908203125 </bigDecimal>
<bigDecimal>0.3000000000000000444089209850062616169452667236328125 </bigDecimal>
<bigDecimal>0.40000000000000002220446049250313080847263336181640625 </bigDecimal>
<bigDecimal>0.5</bigDecimal>
<bigInteger>1</bigInteger>
<bigInteger>2</bigInteger>
<bigInteger>3</bigInteger>
<bigInteger>4</bigInteger>
<bigInteger>5</bigInteger>
<enum>Enum0</enum>
<enum>Enum1</enum>
<enum>Enum2</enum>
<date>2010-01-29T11:22:08.342+0100</date>
<date>2010-02-28T11:22:08.342+0100</date>
<date>2010-03-29T11:22:08.342+0200</date>
<date>2010-04-28T11:22:08.342+0200</date>
<date>2010-05-27T11:22:08.342+0200</date>
<stringArray>stringArray1</stringArray>
<stringArray>stringArray2</stringArray>
<stringArray>stringArray3</stringArray>
<stringArray>stringArray4</stringArray>
<stringArray>stringArray5</stringArray>
<longArray>1</longArray>
<longArray>2</longArray>
<longArray>3</longArray>
<longArray>4</longArray>
<longArray>5</longArray>
</types:ManyTypes>
<types:SingleTypes string="string1" integer="1" integerObject="1" long="1" longObject="1" double="0.1" doubleObject="0.1" float="0.1" floatObject="0.1" char="84" charObject="84" byte="0" byteObject="0" byteArray="00" bigDecimal="0.1000000000000000055511151231257827021181583404541015625 " bigInteger="1" enum="Enum0" date="2010-01-29T11:22:08.340+0100" stringArray="stringArray1" longArray="1" nextEnum="Enum1"/>
</xmi:XMI>
name="xml3.xml"
filename="xml3.xml"
<types:ManyTypes>
<long>1</long>
<long>2</long>
<long>3</long>
<long>4</long>
<long>5</long>
<enum>Enum0</enum>
<enum>Enum1</enum>
<enum>Enum2</enum>
</types:ManyTypes>
</xmi:XMI>
--------------060308090502030902030609--
Re: [EMF Compare] array as eattribute value [message #621996 is a reply to message #621995] |
Thu, 14 January 2010 13:12 |
--------------080104000601080904010101
Hi Martin,
I have recently observed a bug on reference comparison that compared
objects through "==" instead of metrics ... yet haven't took the time to
look further into it yet. Could you raise a bugzilla describing this
(forgot to do it myself :p)? And possibly attach a basic sample, but
that I can live without :).
Laurent Goubet
Obeo
Martin Taal wrote:
> and back work correctly. My model (see attachment) has a number of
> when I persist them to xml/xmi then the two xmi's are exactly the same.
> values are not compared on their content but on 'the same object'
> Object>();
> same).
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------080104000601080904010101--
Re: [EMF Compare] array as eattribute value [message #621999 is a reply to message #621996] |
Thu, 14 January 2010 13:31 |
Hi Laurent,
Ofcourse no problem, I will enter an issue.
Btw, I can also debug and check this myself. So if you can give me a specific class/method I can put a breakpoint or
debug then I can check it myself also.
gr. Martin
Laurent Goubet wrote:
> Hi Martin,
> Laurent Goubet
> Obeo
> Martin Taal wrote:
>> Hi,
>> the array values are not compared on their content but on 'the same
>> object'
>> Object>();
>> same).
The Netherlands
Re: [EMF Compare] array as eattribute value [message #622001 is a reply to message #621999] |
Thu, 14 January 2010 14:34 |
--------------000500040509040202070305
Martin,
Looking at the code to give you pointers ... it seems I had indeed fixed
this back in september (AttributesCheck lines 189 through 202).
Reading a little more closely your question, no, I have never tried with
Arrays :'(. Indeed the problem remains (see
AttributesCheck#areDistinctValues(Object, Object)) which does not differ
whether the "Object" is an array or a random value (other than EObject
and EEnumLiterals). I don't know if there is a way, in Java, to check
whether a random "Object" is an array, but the fix for your issue needs
such a check in this method.
Laurent Goubet
Obeo
Martin Taal wrote:
> Hi Laurent,
> specific class/method I can put a breakpoint or debug then I can check
> it myself also.
> gr. Martin
>> Hi Martin,
>> to look further into it yet. Could you raise a bugzilla describing
>> this (forgot to do it myself :p)? And possibly attach a basic sample,
>> but that I can live without :).
>> Laurent Goubet
>> Obeo
>> Martin Taal wrote:
>>> Hi,
>>> object'
>>> Object>();
>>> Boolean.TRUE);
>>> the same).
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------000500040509040202070305--
Re: [EMF Compare] array as eattribute value [message #622002 is a reply to message #622001] |
Thu, 14 January 2010 14:45 |
Hi Laurent,
Yes indeed there is: object.getClass().isArray().
The efeature.isMany == false for these eattributes (they contain a single value). So I think the solution should be
added to areDistinctValues(...). The Array class in java can be used to generically check length and access values in an
array.
As I like a workaround now, I think I need to create my own DiffEngine inheriting from GenericDiffEngine and overriding
the getAttributesChecker method (to return my own AttributesCheck). Correct?
If it works for me then I will attach the overridden AttributesCheck to the bugzilla I will enter in a few minutes. So
you can make use of it.
gr. Martin
> Martin,
> Laurent Goubet
> Obeo
> Martin Taal wrote:
>> Hi Laurent,
>> it myself also.
>> gr. Martin
>>> Hi Martin,
>>> Laurent Goubet
>>> Obeo
>>> Martin Taal wrote:
>>>> Hi,
>>>> objects and back work correctly. My model (see attachment) has a
>>>> of eobjects, when I persist them to xml/xmi then the two xmi's are
>>>> seems that the array values are not compared on their content but on
>>>> 'the same object'
>>>> Object>();
>>>> Boolean.TRUE);
>>>> emptyMap());
>>>> the same).
The Netherlands
Re: [EMF Compare] array as eattribute value [message #622003 is a reply to message #622002] |
Thu, 14 January 2010 15:09 |
--------------060408070108000705080609
Martin,
Easiest way is to check out EMF Compare sources and patch the
AttributesCheck from there. I didn't know the Class#isArray() method,
but it makes the fix trivial. If you are willing to patch this, the fix
can easily be reviewed and commited for integration within M5.
If you need it before M5 then yes, you need to create your own
DiffEngine to return your implementation of AttributesCheck.
Laurent Goubet
Obeo
Martin Taal wrote:
> Hi Laurent,
> single value). So I think the solution should be added to
> generically check length and access values in an array.
> inheriting from GenericDiffEngine and overriding the
> the bugzilla I will enter in a few minutes. So you can make use of it.
> gr. Martin
>> Martin,
>> fixed this back in september (AttributesCheck lines 189 through 202).
>> with Arrays :'(. Indeed the problem remains (see
>> differ whether the "Object" is an array or a random value (other than
>> EObject and EEnumLiterals). I don't know if there is a way, in Java,
>> to check whether a random "Object" is an array, but the fix for your
>> issue needs such a check in this method.
>> Laurent Goubet
>> Obeo
>> Martin Taal wrote:
>>> Hi Laurent,
>>> gr. Martin
>>>> Hi Martin,
>>>> time to look further into it yet. Could you raise a bugzilla
>>>> describing this (forgot to do it myself :p)? And possibly attach a
>>>> basic sample, but that I can live without :).
>>>> Laurent Goubet
>>>> Obeo
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> It seems that the array values are not compared on their content
>>>>> Object>();
>>>>> Boolean.TRUE);
>>>>> emptyMap());
>>>>> the same).
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------060408070108000705080609--
Current Time: Wed Sep 25 19:38:33 GMT 2024
Powered by FUDForum. Page generated in 0.04244 seconds
