Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Error in opening result.emfdiff
Error in opening result.emfdiff [message #620937] Tue, 12 May 2009 01:52
Hey,
I see these error messages in my EMF Compare editor:
org.eclipse.emf.compare.ui.viewer.structure.ModelStructureMe rgeViewer.updateToolItems(ModelStructureMergeViewer.java:197 )
org.eclipse.emf.compare.ui.viewer.structure.ModelStructureMe rgeViewer.inputChanged(ModelStructureMergeViewer.java:176)
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
org.eclipse.emf.compare.ui.editor.ModelCompareEditorInput.cr eateOutlineContents(ModelCompareEditorInput.java:126)
org.eclipse.emf.compare.ui.editor.ModelCompareEditorInput.cr eateContents(ModelCompareEditorInput.java:96)
org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:415)
org.eclipse.compare.internal.CompareEditor.createPartControl (CompareEditor.java:379)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2635)
org.eclipse.compare.internal.CompareUIPlugin$1.run(CompareUI Plugin.java:454)
org.eclipse.compare.internal.CompareUIPlugin.syncExec(Compar eUIPlugin.java:1171)
org.eclipse.compare.internal.CompareUIPlugin.internalOpenEdi tor(CompareUIPlugin.java:465)
org.eclipse.compare.internal.CompareUIPlugin.openCompareEdit or(CompareUIPlugin.java:429)
org.eclipse.compare.CompareUI.openCompareEditorOnPage(Compar eUI.java:135)
at org.eclipse.compare.CompareUI.openCompareEditor(CompareUI.ja va:121)
org.eclipse.emf.compare.ui.editor.ModelCompareEditorLauncher .open(ModelCompareEditorLauncher.java:38)
at org.eclipse.ui.internal.EditorManager$3.run(EditorManager.ja va:702)
org.eclipse.ui.internal.EditorManager.openExternalEditor(Edi torManager.java:695)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:669)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2817)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Ying
Previous Topic:Error in opening result.emfdiff
Next Topic:When will Mint0.8 M7 release be available?
Current Time: Sun Nov 09 20:37:13 EST 2025
Powered by FUDForum. Page generated in 0.23914 seconds
