Home » Archived » Eclipse Communications Framework (ECF) » MSN encoding Bug
MSN encoding Bug [message #619793] |
Tue, 13 November 2007 07:15 |
Originally posted by: spark.ma.gmail.com
enviroment: OS(XP Sp2), locale(chinese_china)
if contracts nike name or personal message contains chinese character, it will be garbage. This is caused by
when new string the default encoding is OS setting (for me, it is GB18030), but MSN usually uses UTF-8.
It can be fixed by following code (hard code).
Index: src/org/eclipse/ecf/protocol/msn/NotificationSession.java
RCS file:
/cvsroot/technology/org.eclipse.ecf/providers/org.eclipse.ec f.protocol.msn/src/org/eclipse/ecf/protocol/msn/Notification Session.java,v
retrieving revision 1.4
diff -r1.4 NotificationSession.java
127c127
< BufferedReader reader = new BufferedReader(new InputStreamReader(getInputStream()));
> BufferedReader reader = new BufferedReader(new InputStreamReader(getInputStream(), "UTF-8"));
Index: Session.java
RCS file:
/cvsroot/technology/org.eclipse.ecf/providers/org.eclipse.ec f.protocol.msn/src/org/eclipse/ecf/protocol/msn/Session.java ,v
retrieving revision 1.2
diff -r1.2 Session.java
148c148
< return new String(buffer, 0, read).trim();
> return new String(buffer, 0, read, "UTF-8").trim();
276c276
Good luck!
Re: MSN encoding Bug [message #619797 is a reply to message #619793] |
Wed, 14 November 2007 20:42 |
Originally posted by: remy.suen.gmail.com
We actually have a bug open for this. Would you mind attaching your patch
there as an attachment?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=188583
Rem
> RCS file:
> 127c127
> Index: Session.java
> RCS file:
> 148c148
> 276c276
> Good luck!
Re: MSN encoding Bug [message #619798 is a reply to message #619797] |
Thu, 15 November 2007 03:10 |
No problem.
Remy Chi Jian Suen wrote:
> Regards,
> Rem
>> RCS file:
>> 127c127
>> Index: Session.java
>> RCS file:
>> 148c148
>> 276c276
>> Good luck!
Re: MSN encoding Bug [message #619799 is a reply to message #619793] |
Thu, 15 November 2007 05:44 |
I've add more code for MSN which fix the following problem.
1) cann't send DBCS character(such Chinese), which is caused by incorrect message length.
2) can't receive DBCS character, it is caused by incorrect length too.
3) if contract is off-line (blocked), if open message input, it cause infinite loop.
I think ECP is a great works, it very useful for ME!
RCS file:
127c127
Index: src/org/eclipse/ecf/protocol/msn/ChatSession.java
RCS file:
/cvsroot/technology/org.eclipse.ecf/providers/org.eclipse.ec f.protocol.msn/src/org/eclipse/ecf/protocol/msn/ChatSession. java,v
diff -r1.4 ChatSession.java
144c144,145
< while (!joined);
> if (!joined)
> ;//FIXME why need this?
299,300c300,301
< final int text = count - (split[0].length() + 4);
< fireMessageReceivedEvent(contact, split[1].substring(0, text));
> final int text = count - (split[0].getBytes("UTF-8").length + 4); //$NON-NLS-1$
> fireMessageReceivedEvent(contact, new String(split[1].getBytes("UTF-8"), 0, text, "UTF-8")); //$NON-NLS-1$
//$NON-NLS-2$
339c340
< write("MSG", "N " + message.length() + "\r\n" + message, false); //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$
> write("MSG", "N " + message.getBytes("UTF-8").length + "\r\n" + message, false); //$NON-NLS-1$ //$NON-NLS-2$
//$NON-NLS-3$
Index: src/org/eclipse/ecf/protocol/msn/Session.java
RCS file:
148c148
> return new String(buffer, 0, read, "UTF-8").trim(); //$NON-NLS-1$
167c167
< byte[] bytes = newline ? (input + "\r\n").getBytes() : input.getBytes(); //$NON-NLS-1$
> byte[] bytes = newline ? (input + "\r\n").getBytes("UTF-8") : input.getBytes("UTF-8"); //$NON-NLS-1$
> RCS file:
> 127c127
> Index: Session.java
> RCS file:
> 148c148
> 276c276
> Good luck!
Re: MSN encoding Bug [message #619800 is a reply to message #619799] |
Sat, 17 November 2007 01:58 |
Since the newsgroup is covered by the Eclipse terms of use and is
therefore under the EPL, I have committed the suggested changes to CVS
HEAD and have closed bug 188583. Thank you for your assistance.
Rem
Current Time: Fri Apr 26 21:25:25 GMT 2024
Powered by FUDForum. Page generated in 0.03502 seconds
