Home » Archived » Eclipse Communications Framework (ECF) » jingle
jingle [message #619589] Tue, 25 September 2007 02:05 Go to next message
Hello group
How can one try Jingle provider/voIP plugin developed by Moritz Post ?
I am having trouble running this with other example plugins as Moritz
work relies on smak library 3.x and also a modified version of XMPP plugin.
Any help would be highly appreciated.
Roy
Re: jingle [message #619592 is a reply to message #619589] Thu, 27 September 2007 23:12 Go to previous messageGo to next message
Hi Roy,
I'm copying Moritz on this because he can probably answer more definitively.
Moritz' work does rely on Smack 3.x library, and the Smack 3.0 library
requires an alternative version of the xmpp plugin (because Smack 3.0's
XMPP API changed).
The smack3 version of the org.jivesoftware.smack plugin is available here:
:pserver:anonymous@ecf1.osuosl.org:/ecf
in the smack3/org.jivesoftware.smack3 project.
The appropriate version of the xmpp provider plugin
(org.eclipse.ecf.provider.xmpp) is on a branch called:
Smack_3_0_0_v200611056319
We are anticipating eventually moving the Smack_3_0_0... version over to
the mainline, and moving the smack3 version of org.jivesoftware.smack3
over dev.eclipse.org mainline as well, but have not gotten to that. Any
help for those interested would be appreciated.
Scott
roypch@gmail.com wrote:
> Hello group
> Roy
Re: jingle [message #619596 is a reply to message #619592] Sun, 30 September 2007 23:25 Go to previous message
Hi Scott and Moritz
many thanks for the clarification. I did try Moritz SOC work before
posting the query and had problem as rest of my application rely on old
xmpp library.
Pls let me know if i can be of any assistance in the
transitioning/moving to smack 3.x.
thanks again
Roy
Scott Lewis wrote:
> Hi Roy,
> definitively.
> XMPP API changed).
> Scott
>> Hello group
>> plugin.
>> Roy
Previous Topic:IPC
Next Topic:ECF file transfer additions
Current Time: Mon Jun 16 06:46:04 EDT 2025
Powered by FUDForum. Page generated in 0.04234 seconds
