Re: VE 1.4 and Eclipse 3.6 [message #618407 is a reply to message #618403] |
Thu, 01 July 2010 11:46 |
Hi, same problem here. Eclipse Helios for Java Dev.
Cannot complete the install because one or more required items could not be found.
Software being installed: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
Missing requirement: Visual Editor Common Data Editor 1.4.0.v20090826-1446 (org.eclipse.ve.cde 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
Cannot satisfy dependency:
From: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
To: org.eclipse.ve.cde [1.3.0,2.0.0)
My Plugins:
Mobile Tools
PDT
Pydev
Android Plugin for Eclipse.
A quick updaty by the plugin dev would be great.
Thanks!
Pascal
Re: VE 1.4 and Eclipse 3.6 [message #618413 is a reply to message #618403] |
Thu, 08 July 2010 04:13 |
Yves YANG Messages: 688 Registered: July 2009 |
The build for Helios is ongoing. It will be available soon.
Best regards
Yves YANG
"Chris" wrote in message
news:i05njj$ho2$1@build.eclipse.org...
> Hi!
> I have some problems installing VE 1.4 on a fresh Eclipse 3.6 IDE for Java
> EE Developers installation, because i get some dependency errors (see
> below). There are some infos in different threads and in this bugreport:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=301766
> for VE 1.4 and Eclipse 3.5. I have tried to installed only the VE SDK but
> still get the dependency error. Are there any chances to install VE 1.4 on
> Eclipse 3.6 or do we need a new VE version?
> Thanks in advance for a reply.
> Chris
> Dependency error:
> Quote:
>> Cannot complete the install because of a conflicting dependency.
>> Software being installed: Visual Editor SDK
>> 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO
>> (org.eclipse.ve.sdk.feature.group
>> 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
>> Software currently installed: Eclipse IDE for Java EE Developers
>> 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
>> Only one of the following can be installed at once: International
>> Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu
>> 4.2.1.v20100412)
>> International Components for Unicode for Java (ICU4J) 4.0.1.v20090822
>> (com.ibm.icu 4.0.1.v20090822)
>> From: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521
>> To: org.eclipse.epp.package.jee.feature.feature.group
>> [1.3.0.20100617-0521]
>> From: Java EE IDE Feature 1.3.0.20100617-0521
>> (org.eclipse.epp.package.jee.feature.feature.group 1.3.0.20100617-0521)
>> To: org.eclipse.platform.feature.group
>> [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
>> From: Eclipse Platform
>> (org.eclipse.platform.feature.group
>> 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
>> To: org.eclipse.rcp.feature.group
>> [3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS]
>> From: Eclipse RCP 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS
>> (org.eclipse.rcp.feature.group 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS)
>> To: com.ibm.icu [4.2.1.v20100412]
>> To: org.eclipse.ve.java.core [1.3.0,2.0.0)
>> From: Visual Editor Java Core 1.4.0.v20090826-1446
>> (org.eclipse.ve.java.core 1.4.0.v20090826-1446)
>> To: bundle com.ibm.icu [3.4.4.1,4.1.0)
>> From: Visual Editor SDK
>> To: org.eclipse.ve.feature.group
>> [1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk]
[Updated on: Mon, 19 November 2012 14:00] by Moderator Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #631826 is a reply to message #630198] |
Fri, 08 October 2010 23:20 |
hiro nakag Messages: 8 Registered: August 2010 |
Hello.
If VE1.4 installed onto galileo from updatesite didn't work,
it may not work well even if you modify VE1.4 by yourself only the same way that I did.
It seems that it is a problem of VE1.4.
Then, I think that you should try VE1.4 on this page,
if you have not done yet.
It might have to be modified by yourself the same way I did.
Thanks for reading my poor English.
[Updated on: Fri, 08 October 2010 23:38] Report message to a moderator
FUDForum. Page generated in 0.04866 seconds
