"Mark occurrences" in visual editor faulty? [VE on Galileo] [message #618373] |
Tue, 09 March 2010 13:24 |
Jens Mising name Messages: 12 Registered: March 2010 Location: Berlin |
I have the VE installed on Galileo and when I open a visual java file (SWT) and use the text editor (within the visual editor) then the "mark occurence" functionality seems to be defective.
When I mark a variable it will not mark all other occurrences of the variable within the file. However if I toggle the "mark occurrences" function with the shortcut Alt+Shift+O off and on again it works.
Btw: the "java editor" works fine (in terms of marking all occurrences right away).
There seems to be some update problem in the visual editor. Before I file a bug for this, does anyone else experience the same problems?
FUDForum. Page generated in 0.01470 seconds
