Setup java visual editor [message #617326] |
Fri, 30 January 2009 22:19 |
Cihat Eldeniz Messages: 6 Registered: July 2009 |
I have never been able to see the empty form on which you put command
buttons and other objects. I only see the empty palette. What happened was
that, when I use the New Visual Class Wizard, I chose Composite under SWT
and I had already included SWT in the library of the project. Right after
I finished the selections in the wizard, the builder tried to build. It
said setup java visual editor and it freezed at 25% and after some time
"Parse error" appeared in the status bar. If I choose Shell rather than
Composite [under SWT], then things get somewhat worse; it says
"Loading..." and it directly gives the "Parse error" afterwards. I am
writing down the OS and version information and your help in this is
highly appreciated. Thanks in advance.
OS: Windows XP
Eclipse: 3.4
Virtual Editor: 1.2
EMF: 2.4
GEF: 3.4
Java EMF Model: 1.2
FUDForum. Page generated in 0.02491 seconds
