VE not working after installing WST [message #616960] |
Fri, 08 February 2008 10:13 |
alex Messages: 16 Registered: July 2009 |
I am using Eclipse 3.3.0 with VE 1.2.0 which were working perfectly until
i installed WST 2.0.1.
I checked out plugin configuration and everything seems enabled. This are
the log entries:
!ENTRY org.eclipse.ui 4 0 2008-02-08 10:02:04.671
!MESSAGE Unable to create editor ID
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itor: No
editor descriptor for id
!STACK 1
org.eclipse.ui.PartInitException: No editor descriptor for id
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:598)
!SUBENTRY 1 org.eclipse.ui 4 0 2008-02-08 10:02:04.687
!MESSAGE No editor descriptor for id
!ENTRY org.eclipse.jface 4 2 2008-02-08 10:02:04.703
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
!ENTRY org.eclipse.ui 4 0 2008-02-08 10:02:13.343
!MESSAGE Unable to create editor ID org.jbpm.gd.pf.editor: No editor
descriptor for id org.jbpm.gd.pf.editor
!STACK 1
at
at
SUBENTRY 1 org.eclipse.ui 4 0 2008-02-08 10:02:13.343
!MESSAGE No editor descriptor for id org.jbpm.gd.pf.editor
!ENTRY org.eclipse.jface 4 2 2008-02-08 10:02:13.343
!STACK 0
!ENTRY org.eclipse.ui 4 0 2008-02-08 10:02:19.281
!STACK 1
at
!SUBENTRY 1 org.eclipse.ui 4 0 2008-02-08 10:02:19.281
!ENTRY org.eclipse.jface 4 2 2008-02-08 10:02:19.281
!STACK 0
Can anyone explain this and give a workaround to this problem??? I tried
everything, cleaning Eclipse cached, enabling/disabling those two plugins
and reinstalling everything again but nothing works. After a search in
internet i found no answer to this problem, so any help/comments would be
appreciated
FUDForum. Page generated in 0.03511 seconds
