Disable the schemaExport on the hibernate [message #615851] |
Wed, 12 March 2008 18:05 |
Yigal Spinner Messages: 127 Registered: July 2009 |
I'm trying to disable the schema export each time I connect to the
database. It takes a long time to connect and if it is a different
schema it tries to update and that is the wrong solution for production
application.
Here is what I tried:
I create properties for hibernate and assign -
props.setProperty(Environment.HBM2DDL_AUTO, "validate");
dataStore.setHibernateProperties(props);
Please note that I need to use the properties because my application
dynamically changes the database connection with the user input. So I
do not have a configuration file and I manage it via properties.
This should not export the schema but only validate it. However, it
does not have any impact on hibernate. Hibernate always rebuild the schema.
Any ideas how to cause Hibernate not to export the schema.
Tunning it OFF is the best option I'm looking for. Validate is my second.
Yigal
FUDForum. Page generated in 0.07115 seconds
