Home » Archived » Visual Editor (VE) » Putting Multiple Containers in One Content Panel?
Putting Multiple Containers in One Content Panel? [message #615295] Sat, 26 May 2007 02:51
Originally posted by: hal.thresholddigital.com
I'm having a problem with the VE. I have a window with a JPanel as a
ContentPane. I want to set this to a BoxLayout on the Y axis, which I've
done, but then, when I try to add two different panels to it, I can't. I
want to add one panel that will be a strip across the top, as if it were a
menu bar (but it'll be 4-6 buttons instead) and below that I want a
JTabbedPane. Whenever I add either a regular JPanel or the JTabbedPane to
the ContentPane, it fills the entire ContentPane and I can't find any way
to add the other container.
I have no problem putting multiple components in any pane, but once I put
one container in a pane, I can't find a way to put any other containers in.
How can I do this?
Thanks!
Hal
Previous Topic:Putting Multiple Containers in One Content Panel?
Next Topic:VE opens a second window?
Current Time: Thu Nov 06 19:06:58 EST 2025
Powered by FUDForum. Page generated in 0.04244 seconds
