| inaccessible components after cleaning project [message #613761] |
Sat, 12 August 2006 19:38 |
Hello group,
i created a simple composite with the VE (including forms toolkit). It
contains a Section in a ScrolledForm. After cleaning and rebuilding the
project the Section is visible in the editor, but it's no longer
recognized by VE. Neither it's selectable in editor nor shown in Java
Bean View.
Is there a way to make the VE usable again?
Enrico
PS:
my environment
Java 1.5.0_06-b05
eclipse-SDK-3.2-win32
emf-sdo-runtime-2.2.0
GEF-runtime-3.2
VE-runtime-1.2
Windows 2000
the generated class (comments stripped)
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.forms.widgets.FormToolkit;
import org.eclipse.ui.forms.widgets.ScrolledForm;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.ui.forms.widgets.Section;
import org.eclipse.ui.forms.widgets.ExpandableComposite;
public class Test extends Composite {
private FormToolkit formToolkit = null; //
@jve:decl-index=0:visual-constraint=""
private ScrolledForm scrolledForm = null;
private Section section = null;
public Test(Composite parent, int style) {
super(parent, style);
initialize();
private void initialize() {
createScrolledForm();
setSize(new Point(300, 200));
setLayout(new FillLayout());
private FormToolkit getFormToolkit() {
if (formToolkit == null) {
formToolkit = new FormToolkit(Display.getCurrent());
return formToolkit;
private void createScrolledForm() {
scrolledForm = getFormToolkit().createScrolledForm(this);
scrolledForm.getBody().setLayout(new GridLayout());
createSection();
private void createSection() {
section = getFormToolkit().createSection(
scrolledForm.getBody(),
ExpandableComposite.TWISTIE | Section.DESCRIPTION
| ExpandableComposite.TITLE_BAR);
section.setExpanded(true);
FUDForum. Page generated in 0.02871 seconds
