| [TCS] Is "autoCreate=ifmissing" usable? [message #613626] |
Thu, 13 March 2008 10:41  |
Eclipse User  |
I am working on a small example language.
In my TCS syntax, I am trying to use the "autoCreate" parameter like this :
template Program main context
 : assignments
template Assignment
 : variable{refersTo=name, lookIn=owningProgram.variables,
autoCreate=ifmissing} "=" expression ";"
When meeting an assigned variable name, the parser creates a new
"Variable" element and correctly sets the "variables" reference in the
surrounding "Program" element.
The problem is that "ifmissing" seems to have the same effect as "always":
if I use the same variable name in several assignments, several variables
with the same name are created.
Since I found no example using "ifmissing", I am wondering whether this
feature has already been used successfully, and how I could get it to work.
Many thanks for your help,
Guillaume
FUDForum. Page generated in 0.02739 seconds
