| VE 1.2 Integration Driver I20051027 [message #611277] |
Fri, 28 October 2005 10:01 |
http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 1027-200510271200/index.html
Starting with this build, All plugins (VE and JEM) are jars instead of plugin
directories (the same as most Eclipse platform plugins). This will save time
unzipping as well as reducing the amount of files in the overall installation.
If you have a prior VE installation, you should totally remove the JEM and VE
plugin directories before installing this driver. Otherwise, the PDE will get
confused with the directories still there. And, as in prior builds, start
Eclipse with -clean.
Regards...
Peter Walker
VE Development
FUDForum. Page generated in 0.03180 seconds
