Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] Client wont start after CVS update
[CDO] Client wont start after CVS update [message #610211] Mon, 05 November 2007 12:18
Eike,
I did a CVS update this morning and now my client will not start I get the
following output, nothing in the log file.
It just hangs.
Mark.
Configuration location:
file:/home/geib/workspace-cdo-0.80/.metadata/.plugins/org.ec lipse.pde.core/srd.product/
Configuration file:
file:/home/geib/workspace-cdo-0.80/.metadata/.plugins/org.ec lipse.pde.core/srd.product/config.ini
loaded
Install location:
file:/home/geib/eclipse/
Framework located:
file:/home/geib/eclipse/plugins/org.eclipse.osgi_3.3.1.R33x_ v20070828.jar
Framework classpath:
Splash location:
/home/geib/workspace-cdo-0.80/SRDEditor/splash.bmp
Debug options:
file:/home/geib/workspace-cdo-0.80/.metadata/.plugins/org.ec lipse.pde.core/srd.product/.options
loaded
Time to load bundles: 11
Starting application: 1266
main [debug.om] Starting bundle org.eclipse.net4j.util
main [debug.lifecycle] Activating ManagedContainer
main [debug.lifecycle] Activating {}
main [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1
Registry.autoCommit = true
Registry.transaction = null
HashMapRegistry.map =
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors,
tcp]
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.n et4j.randomizers,
default]
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net 4j.userManagers,
file]
org.eclipse.net4j.clientProtocols[cdo]=Factory[org.eclipse.n et4j.clientProtocols,
cdo]
org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors,
tcp]
org.eclipse.net4j.bufferProviders[default]=Factory[org.eclip se.net4j.bufferProviders,
default]
org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors,
tcp]
org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions,
cdo]
org.eclipse.net4j.executorServices[default]=Factory[org.ecli pse.net4j.executorServices,
default]
extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@dfe303
main [debug.lifecycle] Activating []
main [debug.om] Starting bundle org.eclipse.net4j.tcp
main [debug.lifecycle.dump] DUMP PluginElementProcessorList@2
processors =
org.eclipse.emf.internal.cdo.util.ChannelInjector@6a435f
org.eclipse.internal.net4j.Net4jTransportInjector@6d1750
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@15a94f
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@189635d
main [debug.lifecycle.dump] DUMP PluginContainer@3
ManagedContainer.factoryRegistry =
tcp]
default]
file]
cdo]
tcp]
default]
tcp]
cdo]
default]
ManagedContainer.postProcessors =
ManagedContainer.elementRegistry =
ManagedContainer.maxElementID = 0
ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@5ff916
main [debug.om] Plugin container created: ManagedContainer
main [debug.om] Starting bundle org.eclipse.emf.cdo
main [debug.connector] Setting userID null for {2}
main [debug.lifecycle] Activating BufferPool[4,096]
BufferPoolMonitor [debug.buffer] Start monitoring
BufferPoolMonitor [debug.buffer] Stop monitoring
main [debug.lifecycle.dump] DUMP BufferPool@4
BufferProvider.bufferCapacity = 4096
BufferProvider.providedBuffers = 0
BufferProvider.retainedBuffers = 0
provider = BufferFactory[4,096]
pooledBuffers = 0
main [debug.lifecycle] Activating TCPSelector
main [debug.lifecycle.dump] DUMP TCPSelector@5
selector = sun.nio.ch.PollSelectorImpl@16d3536
clientOperations =
serverOperations =
thread = Thread[TCPSelector,6,main]
running = true
main [debug.lifecycle] Activating ClientTCPConnector[localhost:2,036]
main [debug.connector] Setting state CONNECTING (was disconnected) for
main [debug.lifecycle] Activating Channel[Control]
main [debug.lifecycle] Activating QueueWorkerWorkSerializer@6
main [debug.lifecycle.dump] DUMP QueueWorkerWorkSerializer@6
Worker.daemon = false
Worker.activationTimeout = 2000
Worker.deactivationTimeout = 2000
Worker.activationLatch = java.util.concurrent.CountDownLatch@5e7020[Count
= 0]
Worker.workerThread = Thread[Thread-4,6,main]
QueueWorker.queue =
QueueWorker.pollMillis = 100
main [debug.lifecycle.dump] DUMP ControlChannel@7
Channel.channelID = 0
Channel.channelIndex = -1
Channel.connector = ClientTCPConnector[localhost:2,036]
Channel.receiveHandler = null
Channel.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@9a18a0
Channel.receiveSerializer = QueueWorkerWorkSerializer@6
Channel.sendQueue =
registrations = SynchronizingCorrelator{}
main [debug] Ordering client operation REGISTER
java.nio.channels.SocketChannel[unconnected]
TCPSelector [debug] Executing client operation REGISTER
TCPSelector [debug] Registering
TCPSelector [debug] Connecting
java.nio.channels.SocketChannel[connection-pending
remote=localhost/127.0.0.1:2036]
TCPSelector [debug] Ordering client operation INTEREST CONNECT
java.nio.channels.SocketChannel[connected local=/127.0.0.1:33728
remote=localhost/127.0.0.1:2036] = false
TCPSelector [debug] Ordering client operation INTEREST READ
remote=localhost/127.0.0.1:2036] = true
TCPSelector [debug.connector] Setting state CONNECTED (was connecting) for
TCPSelector [debug.lifecycle.dump] DUMP TCPClientConnector@8
Connector.userID = null
Connector.protocolFactoryRegistry =
tcp]
default]
cdo]
tcp]
default]
tcp]
default]
Connector.protocolPostProcessors =
org.eclipse.internal.net4j.Net4jTransportInjector@e9aa13
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@9ce4a3
org.eclipse.emf.internal.cdo.LegacyObjectDisabler@6691da
Connector.negotiator = null
Connector.negotiationContext = null
Connector.bufferProvider = BufferPool[4,096]
Connector.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@9a18a0
Connector.nextChannelID = 1
Connector.channels =
Connector.channelsLock =
org.eclipse.net4j.util.concurrent.RWLock@1f195fc[Write locks = 0, Read
locks = 0]
Connector.connectorState = CONNECTED
Connector.channelListener = org.eclipse.internal.net4j.Connector$1@1add463
Connector.finishedConnecting =
java.util.concurrent.CountDownLatch@152bdc7[Count = 1]
Connector.finishedNegotiating =
java.util.concurrent.CountDownLatch@1296d1d[Count = 1]
TCPConnector.socketChannel = java.nio.channels.SocketChannel[connected
local=/127.0.0.1:33728 remote=localhost/127.0.0.1:2036]
TCPConnector.selector = TCPSelector
TCPConnector.selectionKey = sun.nio.ch.SelectionKeyImpl@8890da
TCPConnector.inputBuffer = null
TCPConnector.controlChannel = Channel[Control]
TCPConnector.host = localhost
TCPConnector.port = 2036
TCPSelector [debug] Executing client operation INTEREST CONNECT
TCPSelector [debug] Setting interest (was connect)
TCPSelector [debug] Executing client operation INTEREST READ
TCPSelector [debug] Setting interest READ
main [debug.om] Starting bundle org.eclipse.emf.cdo.protocol
main [debug.model] Created
CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0, name=cdocore,
dynamic=false, metaIDRange=null)
main [debug.model] Created CDOClass(ID=0, name=CDOObject)
main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)
main [debug.model] Added package:
CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
name=cdoresource, dynamic=false, metaIDRange=null)
main [debug.model] Created CDOClass(ID=0, name=CDOResource)
main [debug.model] Created CDOFeature(ID=8, name=path, type=STRING,
referenceType=null)
main [debug.model] Adding feature: CDOFeature(ID=8, name=path,
type=STRING, referenceType=null)
main [debug.model] Created CDOFeature(ID=2, name=contents, type=OBJECT,
referenceType=CDOClass(ID=0, name=CDOObject))
main [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject))
main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)
main [debug.model] Setting client info:
dynamic=false, metaIDRange=null) -->
org.eclipse.emf.ecore.impl.EcorePackageImpl@14aa2db (name: ecore) (nsURI:
http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOObject) -->
org.eclipse.emf.ecore.impl.EClassImpl@fc8e75 (name: EObject)
(instanceClassName: null) (abstract: false, interface: false)
name=cdoresource, dynamic=false, metaIDRange=null) -->
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@93c4f1 (name:
eresource) (nsURI: http://www.eclipse.org/emf/CDO/resource/1.0.0,
nsPrefix: eresource)
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOResource)
--> org.eclipse.emf.ecore.impl.EClassImpl@f221f6 (name: CDOResource)
main [debug.model] Setting client info: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)) -->
org.eclipse.emf.ecore.impl.EReferenceImpl@166c114 (name: contents)
(ordered: true, unique: true, lowerBound: 0, upperBound: -1) (changeable:
true, volatile: false, transient: false, defaultValueLiteral: null,
unsettable: false, derived: false) (containment: true, resolveProxies:
false)
main [debug.model] Setting client info: CDOFeature(ID=8, name=path,
type=STRING, referenceType=null) -->
org.eclipse.emf.ecore.impl.EAttributeImpl@10e1513 (name: path) (ordered:
true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true,
volatile: false, transient: false, defaultValueLiteral: null, unsettable:
false, derived: false) (iD: false)
main [debug.lifecycle] Activating CDOSession[null/repo1]
main [debug.connector] Waiting for connection...
main [debug.lifecycle] Activating SignalProtocol[cdo]
main [debug.lifecycle.dump] DUMP CDOClientProtocol@9
Protocol.channel = Channel[-32,768]
Protocol.infraStructure = CDOSession[null/repo1]
SignalProtocol.streamWrapper = null
SignalProtocol.signals =
SignalProtocol.nextCorrelationID = 1
main [debug.connector] Opening channel 0 with protocol cdo
main [debug] Registering channel 0 with protocol SignalProtocol[cdo]
main [debug.buffer] Created Buffer@10
main [debug.buffer] Obtained Buffer@10
main [debug.channel] Handling buffer from client: Buffer@10 -->
Channel[Control]
main [debug] Ordering client operation INTEREST WRITE
TCPSelector [debug] Executing client operation INTEREST WRITE
TCPSelector [debug] Setting interest READ|WRITE (was read)
TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected
TCPSelector [debug.buffer] Writing 12 bytes
02 00 00 00 01 00 00 00 03 63 64 6f
TCPSelector [debug.buffer] Retaining Buffer@10
TCPSelector [debug] Ordering client operation INTEREST WRITE
TCPSelector [debug] Setting interest READ (was read|write)
Previous Topic:[Announce] The EclipseCon 2008 Submission Deadline is Rapidly Approaching.
Next Topic:[CDO] No client notifications when changes saved
Current Time: Fri Nov 07 11:49:12 EST 2025
Powered by FUDForum. Page generated in 0.03192 seconds
