Re: WikiText (textile) Markup Question [message #62227 is a reply to message #61960] |
Tue, 25 November 2008 22:08 |
David Green Messages: 136 Registered: July 2009 |
Philip Quitslund wrote:
> Forgive me if this is the wrong forum for this but I haven't seen a more
> appropriate group. Please redirect if I've mis-fired!
This is the right place
> Anyway, I have a
> really simple textile markup question. I'm playing with it as a source
> for my HTML files and am puzzling over how to set a document's title
> (changing the document name is not an ideal option).
As far as I am aware, none of the markup languages supported by WikiText
have syntax for setting the document title. (Textile, MediaWiki,
Confluence, TracWiki and TWiki)
> Inserting this at the beginning of the file:
> <title>Version History</title>
> "works" (sort of), in the sense that it renders correctly (FireFox
> anyway) but the generated markup is not quite right. As you'd expect,
> the title is injected into the body and not into the head:
> <head></head>
> <body>
> <p><title>Version History</title></p>
That's a side-effect of lenient browsers, and this is not really
best-practice (as you noticed)
> So... Is there a more proper way to do this? Is this something I need
> to do in the build phase (e.g., like the <stylesheet> entries in the
> online ant example)? If so, do you have any concrete examples?
The way to do this is via the Ant task. You can specify the title as an
attribute as follows:
<wikitext-to-html markupLanguage="Textile" title="My Title"
file="docs/my-file.textile">
<stylesheet url="docs/styles/main.css"/>
</wikitext-to-html>
I hope that helps.
Re: WikiText (textile) Markup Question [message #595005 is a reply to message #61960] |
David Green Messages: 96 Registered: July 2009 |
Member |
> Anyway, I have a
> <head></head>
> <body>
</wikitext-to-html>
I hope that helps.
FUDForum. Page generated in 0.03965 seconds
