Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Validation action failed due to attribute type is 'long'
Re: Validation action failed due to attribute type is 'long' [message #61497 is a reply to message #61473] |
Wed, 15 November 2006 15:43 |
Andreas Werner Messages: 55 Registered: July 2009 |
Member |
The problem is, that Long is not mapped to the primitive type OCL_INTEGER!
So, in order to compare the class attribute with a constant, the
Long.compareTo method is used, which demands a Long type to compare to.
But the given constant is declared as Integer!
A possible solution is to introduce a new attribute which is of type
long. The OCL expression uses then the new attribute instead of a given
value.
Is there another way to solve this???
Please help, because I don't want to pollute my model with such 'compare
attributes'!!!
Why is the Long type not mapped to OCL_INTEGER???
Alternatively why does OCL_INTEGER not base on Long?
Thanks, Andreas
Andreas Werner wrote:
> Hi newsgroup,
> I defined an attribute invariant via OCL:
> self.property>=0
> If this property has the type EInt everything is fine and the Validation
> action in my GMF editor works as expercted.
> But if the type of the property is changed into ELong, I get a
> 'Validation action failed' message with the following stack trace:
> java.lang.ClassCastException: java.lang.Integer
> at java.lang.Long.compareTo(Unknown Source)
> at org.eclipse.emf.ocl.expressions.impl.EvaluationVisitorImpl.
> visitOperationCallExp(EvaluationVisitorImpl.java:1054)
> at org.eclipse.emf.ocl.expressions.impl.OperationCallExpImpl.ac cept
> (OperationCallExpImpl.java:274)
> at org.eclipse.emf.ocl.query.impl.QueryImpl.evaluate(QueryImpl. java:242)
> at org.eclipse.emf.ocl.query.impl.QueryImpl.check(QueryImpl.jav a:278)
> Is that OCL expression not applicable for 'long' properties?
> Thanks, Andreas
> PS: I'm using version 1.01 of EMFT OCL.
Re: Validation action failed due to attribute type is 'long' [message #61520 is a reply to message #61497] |
Wed, 15 November 2006 16:32 |
Hi, Andreas,
Yes, the OCL Integer type should be implemented by Long. Would you mind
opening a bug report?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& version=1.0.1&component=UML2%20OCL&bug_severity=norm al&form_name=enter_bug
Also, as this is an OCL problem, I am replying to the MDL UML2 OCL
newsgroup, which is the new home of the OCL component.
Christian
> value.
> attributes'!!!
> Thanks, Andreas
>> Hi newsgroup,
>> self.property>=0
>> Thanks, Andreas
Re: Validation action failed due to attribute type is 'long' [message #595686 is a reply to message #61473] |
Member |
value.
attributes'!!!
Thanks, Andreas
> Hi newsgroup,
> self.property>=0
> Thanks, Andreas
Re: Validation action failed due to attribute type is 'long' [message #595695 is a reply to message #61497] |
Hi, Andreas,
Christian
> value.
> attributes'!!!
> Thanks, Andreas
>> Hi newsgroup,
>> self.property>=0
>> Thanks, Andreas
Current Time: Fri Apr 26 11:04:37 GMT 2024
Powered by FUDForum. Page generated in 0.03288 seconds
