Can't get XMPPClient to work [message #607577] |
Mon, 04 September 2006 10:28 |
Originally posted by: ronny.duwyn.agfa.com
Has anyone tried the XMPPClient or XMPPChatClient in release 0.9.0 ?
I started a server: localhost:3282.
I'm running (debugging) a XMPPClient (robot) to get an understanding of
how it all works, but at
XMPPChatClient line 86:
getContainer().connect(targetID,ConnectContextFactory.create PasswordConnectContext(password));
it fails.
The server generates following error:
(trace)connection[09/04/06;12:18:49:371]accept:/127.0.0.1
(trace)connection[09/04/06;12:18:49:402]Unexpected exception in
handleAccept...closing
java.io.StreamCorruptedException: invalid stream header
at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
at java.io.ObjectInputStream.<init>(Unknown Source)
org.eclipse.ecf.provider.generic.TCPServerSOContainerGroup.h andleAccept(TCPServerSOContainerGroup.java:99)
at org.eclipse.ecf.provider.comm.tcp.Server$2.run(Server.java:8 2)
at java.lang.Thread.run(Unknown Source)
an the client this one:
java.net.SocketException: Software caused connection abort: socket write
error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at sun.nio.cs.StreamEncoder$CharsetSE.writeBytes(Unknown Source)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlushBuffer(Unknown Source)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlush(Unknown Source)
at sun.nio.cs.StreamEncoder.flush(Unknown Source)
at java.io.OutputStreamWriter.flush(Unknown Source)
at java.io.BufferedWriter.flush(Unknown Source)
at org.jivesoftware.smack.PacketWriter.writePackets(PacketWrite r.java:242)
at org.jivesoftware.smack.PacketWriter.access$2(PacketWriter.ja va:232)
at org.jivesoftware.smack.PacketWriter$1.run(PacketWriter.java: 70)
org.xmlpull.v1.XmlPullParserException: only whitespace content allowed
before start tag and not \ufffd (position: START_DOCUMENT seen \ufffd...
@1:1)
at org.xmlpull.mxp1.MXParser.parseProlog(MXParser.java:1542)
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1418)
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1137)
at org.jivesoftware.smack.PacketReader.parsePackets(PacketReade r.java:377)
at org.jivesoftware.smack.PacketReader.access$0(PacketReader.ja va:275)
at org.jivesoftware.smack.PacketReader$1.run(PacketReader.java: 63)
What am i doing wrong?
Thanx for a response in advance
FUDForum. Page generated in 0.04083 seconds
