Re: Dragging existing SysML blocks into block definition diagrams doesn't work [message #607450 is a reply to message #607445] |
Wed, 15 September 2010 08:55 |
Hi Markus,
Looks like a bug as you should definitively be able to drag and drop
blocks from model explorer in a BDD.
Can you please open a bug in the bugzilla?
thanks
raphaël
Le 14/09/2010 15:23, Markus Lorenz a écrit :
> Hey guys,
> I'm not sure if this is a bug or if I'm missing something.
> I have some existing SysML blocks which I use in an internal block
> diagram. Now I want to use the same blocks in a block definition
> diagram. I tried dragging them from the Model Explorer into the diagram,
> but the dropping is not allowed.
> What works is creating new blocks directly into the diagram by selecting
> "Block" from the Palette. But when I remove them I can never put them
> back into the diagram again.
> Dragging existing blocks from the Model Explorer into block definition
> diagrams is not working. It's no problem with internal block diagrams,
> though.
> Any ideas?
> Regards,
> Markus
FUDForum. Page generated in 0.02487 seconds
