Re: Problem with Help system in Eclipse 3.3.1.1 [message #606948] |
Sun, 20 January 2008 05:06 |
Originally posted by: nospam_kowalskilee.gmail.com
Anand Narasimhan wrote:
> I am seeing a strange problem in the help system in 3.3.1.1. In our RCP
> application, we have online help. If I click on a topic in the contents
> window, the help for the wrong topic is shown. For example if I have the
> following topics
> Main Topic
> - Sub Topic 1
> - Sub Topic 2
> - Sub Topic 3
> - Sub Topic 4
> If I click on Sub Topic 1, I see a document with just a title that says
> "What's New"
> If I click on Sub Topic 3, I see the contents for Sub Topic 1
> If I click on Sub Topic 4, I see the contents for Sub Topic 2
> and so on.
> The same help plug-ins seems to work fine in 3.2 and 3.4.
> Is there a bug in 3.3 in the help system that would cause this problem?
> Thanks
> Anand
I'm adding the eclipse.platform.ua newsgroup to this thread, as that
newsgroup covers the help system.
Anand, can you provide here the portion of your toc.xml file that has
the contents that is related to the "Main Topic" and "Sub Topics" that
are showing this behavior?
I'm not aware of any bug in 3.3 that would cause this particular
problem. Do you have a document with a title that is "What's New"? Did
the toc.xml file get changed somehow without shutting down and
restarting the application? Are you starting up with the the osgi
parameter -clean to refresh the Eclipse configuration state between
startups/shutdowns?
--Lee Anne
FUDForum. Page generated in 0.03180 seconds
