Home » Modeling » MDT (Model Development Tools) » MDT Installation with sources
MDT Installation with sources [message #606552] Fri, 30 July 2010 05:12 Go to next message
Ashwani Kr Sharma is currently offline Ashwani Kr SharmaFriend
I am building my tools over MDT. But the installation does not have sources. Sometime to debug into the code, i need to download from CVS.
Is there any installation which contains the sources ?
Ashwani Kr Sharma
Re: MDT Installation with sources [message #606554 is a reply to message #606552] Fri, 30 July 2010 05:22 Go to previous message
Hi Ashwani
Most Eclipse tools are distributed with source plugins which provide the
'missing' sources when you do File->Import...->Plugin Development->
Plugins and Fragments then Import As->Projects with Source Folders.
Just occasionally, as with EMF's ANT tasks there is a less obvious
secondary source ZIP.
If this does not provide sources file a bug against the relevant
project, and check the sources out of CVS.
ed Willink
On 30/07/2010 06:12, Ashwani Kr Sharma wrote:
> Regards,
> Ashwani Kr Sharma
Previous Topic:MDT Installation with sources
Next Topic:[BPMN2] Missing namespace export for XSD-based serialization
Current Time: Sun Oct 01 13:27:42 GMT 2023
Powered by FUDForum. Page generated in 0.01894 seconds
