[BPMN2] Using the BPMN2 editor XML as input for ATL [message #606547] |
Mon, 26 July 2010 09:11  |
Hi all,
I'm defnining a transformation in ATL, which uses the BPMN2 metamodel as source.
I'd like to use the output XML from the BPMN2 editor as input for the ATL transformation. This does however not work. The output XML from the editor looks like this (conforming the BPMN2 xsd schema):
<bpmn2:definitions xmlns:bpmn2="http://www.omg.org/spec/BPMN/20100524/MODEL-XMI" id="sid-Definitions">
<bpmn2:process id="sid-Process">
<bpmn2:startEvent id="sid-StartEvent">
<bpmn2:outgoing>sid-SF1</bpmn2:outgoing>
</bpmn2:startEvent>
<bpmn2:task id="sid-Task">
<bpmn2:incoming>sid-SF1</bpmn2:incoming>
<bpmn2:outgoing>sid-SF2</bpmn2:outgoing>
</bpmn2:task>
<bpmn2:endEvent id="sid-EndEvent">
<bpmn2:incoming>sid-SF2</bpmn2:incoming>
</bpmn2:endEvent>
<bpmn2:sequenceFlow id="sid-SF1" sourceRef="sid-StartEvent" targetRef="sid-Task"/>
<bpmn2:sequenceFlow id="sid-SF2" sourceRef="sid-Task" targetRef="sid-EndEvent"/>
</bpmn2:process>
</bpmn2:definitions>
This does conform to the BPMN metamodel, however, this is not excepted by ATL, because "definitions", "task", etc. ain't classes defined in the metamodel (rather they are attributes). A valid XML format accepted by ATL is the following:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns="platform:/resource/Cent2Decent/BPMN.ecore">
<Definitions id="Process1" xmi:id="Process1">
<rootElements xmi:type="Process" id="sid-Process" name="Process1" xmi:id="sid-Process">
<flowElements xmi:type="Task" name="Task1" id="sid-Task1" xmi:id="sid-Task"/>
<flowElements xmi:type="StartEvent" name="StartEvent" id="sid-StartEvent" xmi:id="sid-StartEvent"/>
<flowElements xmi:type="EndEvent" name="EndEvent" id="sid-EndEvent" xmi:id="sid-EndEvent"/>
<flowElements xmi:type="SequenceFlow" name="SF1" id="sid-SF1" sourceRef="sid-StartEvent" targetRef="sid-Task1" xmi:id="sid-SF1"/>
<flowElements xmi:type="SequenceFlow" name="SF2" id="sid-SF2" sourceRef="sid-Task1" targetRef="sid-EndEvent" xmi:id="sid-SF2"/>
</rootElements>
</TDefinitions>
</xmi:XMI>
Is there a way to switch between the two representations? Or is there a way to load the first XML file directly in ATL?
Re: [BPMN2] Using the BPMN2 editor XML as input for ATL [message #724360 is a reply to message #723874] |
Mon, 12 September 2011 03:29  |
Hello Ivanna,
why do you want to explicitly generate a closing tag instead of an empty-element tag, both being semantically equivalent? Note that your preferred version will be generated as soon as you have some child elements to the definitions element.
I'm not aware of any options that control this behavior.
Henning
FUDForum. Page generated in 0.04479 seconds
