Home » Modeling » Papyrus » Export to PNG and Problems with class diagrams
Re: Export to PNG and Problems with class diagrams [message #606927 is a reply to message #606046] |
Tue, 31 August 2010 13:18 |
Markus Lorenz Messages: 11 Registered: August 2010 |
Angi wrote on Tue, 24 August 2010 06:10
> There is no print symbol, no print in the menu, oder something like save as image.
Maybe you misunderstood Patrick?
The option to export images can be found in the context menu. You have to click into the diagram with the right button of your mouse.Then the context menu appears next to your mouse pointer. The option can not be found in the menu at the top of the window!
In the context menu there are several items starting with "Filter views...", "Add", "Navigate", and the fourth item is "File". Inside "File" you can find "Save As Image File...". You can choose between several formats like GIF, PNG, SVG, and PDF in the dialog. Though PDF is not working for me.
Re: Export to PNG and Problems with class diagrams [message #677253 is a reply to message #676573] |
Tue, 07 June 2011 22:27 |
Yann Tanguy Messages: 80 Registered: July 2009 |
Member |
(Tested on Papyrus 0.8.0 RC3)
With the diagram open, right-click anywhere in the diagram, then select
"File/Save as image file".
regards,
Yann
On Sun, 05 Jun 2011 13:16:31 +0200, <forums-noreply@eclipse.org> wrote:
> Hello,
> I want to export the diagramas I have created with Papyrus over eclipse
> helios as an image. I have tried what Markus wrote but I can't find the
> option "Save as image file". I have tried the option "Export...", but I
> can't find image file type in the output types supported. I tried to
> install this plugin ("Image export", it allows exporting GEM/GMF
> diagrams to images ), which is in the eclipse marketplace, but when I
> find it in the plugin list, there isn't an install button next to it, so
> I can't install it.
> I want to know what is the problem or if there is other choice to export
> as image or print a papyrus diagram.
> Thanks in advance
Using Opera's revolutionary email client: http://www.opera.com/mail/
Current Time: Wed Sep 25 10:47:50 GMT 2024
Powered by FUDForum. Page generated in 0.05447 seconds
