Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » How to declare type of empty collection in OCL?
Re: How to declare type of empty collection in OCL? [message #61256 is a reply to message #61231] |
Tue, 14 November 2006 11:21 |
Tord,
I'll forward your question to the new OCL newsgroup.
Tord Alenljung wrote:
> How can I declare that for example a Set contains objects of some type
> and then initialize it to be empty. Neither I or II below works, but
> III does.
> (I) Not OK
> let a:Set(Integer)=Set{} in a
> 'Init expression type does not conform to type of variable (a).'
> (II) Not OK
> let a:Set(Integer)=Set(Integer){} in a
> '1:20:1:31 "collectionTypeIdentifierCS" expected instead of
> "Set(Integer)"'
> (III) OK
> let a:Set(Integer)=Set{1,3,2} in a
> 2
> 1
> 3
> Regards
> Tord
Re: How to declare type of empty collection in OCL? [message #61376 is a reply to message #61256] |
Tue, 14 November 2006 14:12 |
Hi, Tord,
The element type of a collection literal is inferred from its contents (as
the common supertype of its elements, which may be OclAny or
Collection(OclAny) in mixed cases). The inferred element type of an empty
collection literal is OclVoid, which conforms to all other types, so your
expression (I) should work.
This is a bug. Would you mind raising it? (on the MDT UML2 OCL component):
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& version=1.0.1&component=UML2%20OCL&bug_severity=norm al&form_name=enter_bug
Christian
Ed Merks wrote:
> Tord,
>> III does.
>> (I) Not OK
>> (II) Not OK
>> "Set(Integer)"'
>> (III) OK
>> 2
>> 1
>> 3
>> Regards
>> Tord
Re: How to declare type of empty collection in OCL? [message #61449 is a reply to message #61376] |
Wed, 15 November 2006 12:11 |
Tord Alenljung Messages: 4 Registered: July 2009 |
Bug report at https://bugs.eclipse.org/bugs/show_bug.cgi?id=164614
Tord
Christian W. Damus wrote:
> Hi, Tord,
> Christian
> Ed Merks wrote:
>> Tord,
>>> III does.
>>> (I) Not OK
>>> (II) Not OK
>>> "Set(Integer)"'
>>> (III) OK
>>> 2
>>> 1
>>> 3
>>> Regards
>>> Tord
Re: How to declare type of empty collection in OCL? [message #595597 is a reply to message #61231] |
Ed Merks Messages: 33141 Registered: July 2009 |
Tord,
> III does.
> (I) Not OK
> (II) Not OK
> "Set(Integer)"'
> (III) OK
> 2
> 1
> 3
> Regards
> Tord
Ed Merks
Re: How to declare type of empty collection in OCL? [message #595643 is a reply to message #61256] |
Hi, Tord,
Christian
Ed Merks wrote:
> Tord,
>> III does.
>> (I) Not OK
>> (II) Not OK
>> "Set(Integer)"'
>> (III) OK
>> 2
>> 1
>> 3
>> Regards
>> Tord
Re: How to declare type of empty collection in OCL? [message #595666 is a reply to message #61376] |
Tord
> Hi, Tord,
> Christian
> Ed Merks wrote:
>> Tord,
>>> III does.
>>> (I) Not OK
>>> (II) Not OK
>>> "Set(Integer)"'
>>> (III) OK
>>> 2
>>> 1
>>> 3
>>> Regards
>>> Tord
Current Time: Fri Apr 26 03:29:59 GMT 2024
Powered by FUDForum. Page generated in 0.03392 seconds
