Home » Eclipse Projects » Plugin Development Environment (PDE) » Including Root Files in a Product Build
Including Root Files in a Product Build [message #604934] Tue, 09 March 2010 08:31 Go to next message
I have a PDE headless build for my product (plugins-based), which works well.
Now I need to add a couple of files to my product, and I (try to) follow guidelines from this article : http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .pde.doc.user/tasks/pde_rootfiles.htm, ie.create a feature that contributes rootfiles, but does not specify a bin.includes property, and use the featureList property to select this feature.
So:
- I created a feature for root files only (its build.properties only contains root=rootfiles, with the rootfiles folder containing the two extra-files I need)
- the headless build works fine, without error
- at the end, I see that ${buildDirectory}/repository/binary contains a binary file that corresponds to the feature I created for root files. If I open this binary files in an hex editor I can see, among other things, the names of the root files I want to add.
But finally, the produced zip doesn't contain the root files. At its root I only see (just like before trying to add root files) the exe launcher, the ini file, and artifact.xml
Any hint?
Thanks in advance for your help,
Yves
Yves Monier
Re: Including Root Files in a Product Build [message #658298 is a reply to message #604934] Mon, 07 March 2011 13:03 Go to previous messageGo to next message
I did come across with the same issue.
It worked well with previous Eclipse versions (Ganymede, Galileo), but now
I use the new productBuild.xml ant template (which is pretty different
from its predecessors), and the root files are not copied in outcome
product archive.
The configuration is:
[1] productBuild.xml
<target name="main" description="the main build target">
<antcall target="preBuild" />
<antcall target="processRepos" />
<antcall target="generateFeature">
<!-- Generate the feature to drive the fetch -->
<param name="verify" value="false" />
</antcall>
<antcall target="fetch" />
<!-- We are calling generate feature a second time so that we can get
the pack / unpack clause fixed -->
<param name="verify" value="true" />
</antcall>
<antcall target="generate" />
<antcall target="process" />
<antcall target="assemble" />
<antcall target="package" />
<antcall target="postBuild" />
</target>
<!-- Generate a container feature based on the product
file -->
<!-- The plugin or feature containing the .product file will need to
exist -->
<!-- already, use preSetup or postSetup to fetch it if
necessary -->
<target name="generateFeature">
<eclipse.generateFeature
featureId="org.eclipse.pde.build.container.feature"
buildDirectory="${buildDirectory}" baseLocation="${baseLocation}"
productFile="${product}" verify="${verify}"
pluginPath="${transformedRepoLocation}${path.separator}${pluginPath} "
configInfo="${configs}" pluginList="${pluginList}"
featureList="${featureList}" includeLaunchers="${includeLaunchers}"
buildPropertiesFile="${generatedBuildProperties}"
nestedInclusions="${nestedInclusions}" filterP2Base="${filterP2Base}" />
</target>
[2] Feature's build.properties:
bin.includes = feature.xml,\
root=rootfiles
[3] Feature layout
build.properties
feature.xml
rootfiles
- license.html
Is there an additional setting which enable the root files support in
build.properties, or did I miss smth?
Jtonic
On Tue, 09 Mar 2010 15:31:03 +0200, Yves Monier <yves.monier@gmail.com>
wrote:
> Hello,
> well.
> feature.
> So:
> extra-files I need)
> the names of the root files I want to add. But finally, the produced zip
> artifact.xml
> Any hint?
> Yves
Respect
jtonic
Re: Including Root Files in a Product Build [message #658317 is a reply to message #658298] Mon, 07 March 2011 14:55 Go to previous message
------------Mem8aJIu0y1LG2MEOfRjAu
Content-Type: text/plain; charset=iso-8859-15; format=flowed; delsp=yes
I did manage to configure the product generation related files [1] so as
the root files went in outcome archives.
Reading carefully here [1], I've noticed there are 2 ways to include Root
Files in a product build.
The last worked for me.
Quote
${buildDirectory}/build.properties: generatedBuildProperties =
${buildDirectory}/root.properties
${buildDirectory/root.properties: root =
absolute:${buildDirectory}/rootfiles
${buildDirectory}/rootfiles/*
Also, I did a mistake in my previous post when I've said the
productBuild.xml ANT template was changed significantly in Helios
(${eclipse_home}\plugins\org.eclipse.pde.build**\scripts\pro ductBuild\productBuild.xml)
In fact my older productBuild.xml build script was a custom one.
The changes in Helios include:
[1] productBuild.xml, build.properties & root.properties
[2]
Jtonic
On Mon, 07 Mar 2011 20:03:38 +0200, Jtonic <antonel.pazargic@gmail.com>
> now I use the new productBuild.xml ant template (which is pretty
> different from its predecessors), and the root files are not copied in
> outcome product archive.
> </antcall>
> <!-- We are calling generate feature a second time so that we can getthe
> </antcall>
> </target>
> <!-- Generate a container feature based on the productfile -->
> exist -->
> <!-- already, use preSetup or postSetup to fetch it ifnecessary -->
> </target>
> root=rootfiles
> [3] Feature layout
> build.properties
> feature.xml
> rootfiles
> - license.html
> Regards
> Jtonic
> wrote:
>> Hello,
>> well.
>> Now I need to add a couple of files to my product, and I (try to)follow
>> feature.
>> So:
>> extra-files I need)
>> binary file that corresponds to the feature I created for root files.If
>> I open this binary files in an hex editor I can see, among otherthings,
>> the names of the root files I want to add. But finally, theproduced zip
>> doesn't contain the root files. At its root I only see(just like before
>> trying to add root files) the exe launcher, the inifile, and
>> artifact.xml
>> Any hint?
>> Yves
Respect
jtonic
Content-Type: multipart/related; boundary=----------Mem8aJIu0y1LG25T4zbuOr
------------Mem8aJIu0y1LG25T4zbuOr
Content-Type: text/html; charset=iso-8859-15
Content-ID: <op.1299527743875.65cf6d546d5dd36a@192.168.0.103>
Content-Transfer-Encoding: Quoted-Printable
<!DOCTYPE html><html><head><style type=3D"text/css">body { font-family:'=
Times New Roman'; font-size:17px}</style></head><body><div>I did manage =
to configure the product generation related files [1] so as the root fil=
es went in outcome archives.</div><div><br>Reading carefully here [1], I=
've noticed there are 2 ways to include Root Files in a product build.<b=
r>The last worked for me.&nbsp;<br><br>Quote<br>&gt;&gt;&gt;&gt; <br> ${b=
uildDirectory}/build.properties: generatedBuildProperties =3D ${buildDi=
rectory}/root.properties<br> ${buildDirectory/root.properties: root =3D=
absolute:${buildDirectory}/rootfiles<br> ${buildDirectory}/rootfiles/*<=
br>&lt;&lt;&lt;<br><br>Also, I did a mistake in my previous post when I'=
ve said the productBuild.xml ANT template was changed significantly in H=
elios (${eclipse_home}\plugins\org.eclipse.pde.build**\scripts\pro ductBu=
ild\productBuild.xml) .&nbsp;</div><div>In fact my older productBuild.xm=
l build script was a custom one.</div><div><br></div><div>The changes in=
Helios include:</div><div><br> nestedInclusions=3D"${nestedInclusions}=
"<br> filterP2Base=3D"${filterP2Base}"<br><br>[1] productBuild.xml, bui=
ld.properties &amp; root.properties<br>[2] http://help.eclipse.org/galil=
eo/index.jsp?topic=3D/org.eclipse.pde.doc.user/tasks/pde_roo tfiles.htm <=
br><br>Regards<br><br>Jtonic<br><br>On Mon, 07 Mar 2011 20:03:38 +0200, =
Jtonic &lt;antonel.pazargic@gmail.com&gt; wrote:<br><br>&gt; I did come =
across with the same issue.<br>&gt; It worked well with previous Eclipse=
versions (Ganymede, Galileo), but <br>&gt; now I use the new productBu=
ild.xml ant template (which is pretty <br>&gt; different from its pred=
ecessors), and the root files are not copied in <br>&gt; outcome produc=
t archive.<br>&gt;<br>&gt; The configuration is:<br>&gt;<br>&gt; [1] pro=
ductBuild.xml<br>&gt;<br>&gt; &lt;target name=3D"main" description=3D"t=
he main build target"&gt;<br>&gt; &lt;antcall target=3D"preBuild" /&gt=
;<br>&gt; &lt;antcall target=3D"processRepos" /&gt;<br>&gt; &lt;antc=
all target=3D"generateFeature"&gt;<br>&gt; &lt;!-- Generate the featu=
re to drive the fetch --&gt;<br>&gt; &lt;param name=3D"verify" value=3D=
"false" /&gt;<br>&gt; &lt;/antcall&gt;<br>&gt; &lt;antcall target=3D=
"fetch" /&gt;<br>&gt; &lt;antcall target=3D"generateFeature"&gt;<br>&g=
t; &lt;!-- We are calling generate feature a second time so that we c=
an get <br>&gt; the pack / unpack clause fixed --&gt;<br>&gt; &lt;pa=
ram name=3D"verify" value=3D"true" /&gt;<br>&gt; &lt;/antcall&gt;<br>&=
gt; &lt;antcall target=3D"generate" /&gt;<br>&gt; &lt;antcall target=
=3D"process" /&gt;<br>&gt; &lt;antcall target=3D"assemble" /&gt;<br>&g=
t; &lt;antcall target=3D"package" /&gt;<br>&gt; &lt;antcall target=3D=
"postBuild" /&gt;<br>&gt; &lt;/target&gt;<br>&gt;<br>&gt; &lt;!-- <br=
>&gt; =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D --=
&gt;<br>&gt; &lt;!-- Generate a container feature based on the product =
<br>&gt; file --&gt;<br>&gt; &lt;!-- The plugin or feat=
ure containing the .product file will need to <br>&gt; exist --&gt;<br>=
&gt; &lt;!-- already, use preSetup or postSetup to fetch it if <br>&gt=
; necessary --&gt;<br>&gt; &lt;!-- <br>&gt; =3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D --&gt;<br>&gt; &lt;target=
name=3D"generateFeature"&gt;<br>&gt; &lt;eclipse.generateFeature <br=
>&gt; featureId=3D"org.eclipse.pde.build.container.feature" <br>&gt; bu=
ildDirectory=3D"${buildDirectory}" baseLocation=3D"${baseLocation}" <br=
>&gt; productFile=3D"${product}" verify=3D"${verify}" <br>&gt; pluginPa=
th=3D"${transformedRepoLocation}${path.separator}${pluginPath} " <br>&gt=
; configInfo=3D"${configs}" pluginList=3D"${pluginList}" <br>&gt; featu=
reList=3D"${featureList}" includeLaunchers=3D"${includeLaunchers}" <br>=
&gt; buildPropertiesFile=3D"${generatedBuildProperties}" <br>&gt; neste=
dInclusions=3D"${nestedInclusions}" filterP2Base=3D"${filterP2Base}" /&g=
t;<br>&gt; &lt;/target&gt;<br>&gt;<br>&gt;<br>&gt; [2] Feature's build.=
properties:<br>&gt; bin.includes =3D feature.xml,\<br>&gt; =
root=3Drootfiles<br>&gt;<br>&gt; [3] Feature layout<br>&gt; build.pro=
perties<br>&gt; feature.xml<br>&gt; rootfiles<br>&gt; - license.html<=
br>&gt;<br>&gt; Is there an additional setting which enable the root fil=
es support in <br>&gt; build.properties, or did I miss smth?<br>&gt;<br=
>&gt; Regards<br>&gt;<br>&gt; Jtonic<br>&gt;<br>&gt;<br>&gt;<br>&gt; <br>=
&gt; On Tue, 09 Mar 2010 15:31:03 +0200, Yves Monier &lt;yves.monier@gma=
il.com&gt; <br>&gt; wrote:<br>&gt;<br>&gt;&gt; Hello,<br>&gt;&gt;<br>&g=
t;&gt; I have a PDE headless build for my product (plugins-based), which=
works <br>&gt;&gt; well.<br>&gt;&gt; Now I need to add a couple of fil=
es to my product, and I (try to) <br>&gt;&gt; follow guidelines from th=
is article : <br>&gt;&gt; <a href=3D"http://help.eclipse.org/galileo/in=
dex.jsp?topic=3D/org.eclipse.pde.doc.user/tasks/pde_rootfile s.htm ">http:=
//help.eclipse.org/galileo/index.jsp?topic=3D/org.eclipse.pd e.doc.user/t=
asks/pde_rootfiles.htm</a>, <br>&gt;&gt; ie.create a feature that contr=
ibutes rootfiles, but does not specify a <br>&gt;&gt; bin.includes prop=
erty, and use the featureList property to select this <br>&gt;&gt; feat=
ure.<br>&gt;&gt;<br>&gt;&gt; So:<br>&gt;&gt; - I created a feature for r=
oot files only (its build.properties only <br>&gt;&gt; contains root=3D=
rootfiles, with the rootfiles folder containing the two <br>&gt;&gt; ex=
tra-files I need)<br>&gt;&gt; - the headless build works fine, without e=
rror<br>&gt;&gt; - at the end, I see that ${buildDirectory}/repository/b=
inary contains a <br>&gt;&gt; binary file that corresponds to the featu=
re I created for root files. <br>&gt;&gt; If I open this binary files i=
n an hex editor I can see, among other <br>&gt;&gt; things, the names o=
f the root files I want to add. But finally, the <br>&gt;&gt; produced =
zip doesn't contain the root files. At its root I only see <br>&gt;&gt;=
(just like before trying to add root files) the exe launcher, the ini =
<br>&gt;&gt; file, and artifact.xml<br>&gt;&gt;<br>&gt;&gt; Any hint?<br=
>&gt;&gt; Thanks in advance for your help,<br>&gt;&gt;<br>&gt;&gt; Yves<=
br>&gt;&gt;<br>&gt;<br>&gt;<br><br><br ></div><div id=3D"M2Signature"><di=
v>-- </div><div><div><em>Respect</em><br><br><strong><big ><big>jtonic</b=
ig></big></strong><br></div></div></div></body></html >
------------Mem8aJIu0y1LG25T4zbuOr--
------------Mem8aJIu0y1LG2MEOfRjAu--
Previous Topic:PDE Build with p2.gathering and root files fails.
Next Topic:Create a plugin for extending editors
Current Time: Mon Nov 03 19:35:28 EST 2025
Powered by FUDForum. Page generated in 0.04592 seconds
