Re: How to authenticate contributing extension? [message #604729 is a reply to message #604712] |
Thu, 18 February 2010 12:59 |
Vijay Raj Messages: 608 Registered: July 2009 |
Its like "should i have the cake or eat it...".
Either you can have extendability or restrict ability...
you can not have both...
But in your case you need both(but i think it would be better to not use extensions for it)....
The solution can be...
You can have a getter method in your adapter interface
which returns a encrypted key value,which then can be authenticated by your main application...
off coarse your licensing adapter plugin should be obstruficated so that the key can not be retrieved...
Vijay
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
FUDForum. Page generated in 0.03256 seconds
