Re: XML generation from XSD puts "token" in attributes [message #604421 is a reply to message #604417] |
Wed, 18 November 2009 19:53 |
Ed Merks Messages: 33142 Registered: July 2009 |
Nick,
The XSD project doesn't provide that action. Maybe the web tools
project does. I've added it to the "to" list of the reply.
Nick Radov wrote:
> I would like to generate some sample XML files for testing based on an
> XSD. So I used the "Generate, XML File..." command and it did create a
> file. Unfortunately, many of the attributes in the generated file are
> set to "token" which doesn't pass schema validation. The XSD defines a
> limited set of allowable values for those attributes.
> Is there any way to make it generate correct attribute values?
> Unfortunately I can't post the XSD files here to reproduce the problem
> because they are copyright by HL7. If anyone happens to be an HL7
> member you can download the CDA.xsd file from the
> http://www.hl7.org/implement/standards/cda.cfm page in the "CDA
> Release 2" package.
Ed Merks
FUDForum. Page generated in 0.03608 seconds
