Home » Archived » Memory Analyzer (MAT) » Configuring JRE for running MAT
Configuring JRE for running MAT [message #5441] Tue, 14 October 2008 13:57 Go to next message
On a Win64 x64 machine, my JAVA_HOME (and PATH) point to a 32-bit JDK -
primarily used for running maven.
How can I configure MAT to run using a specific x64 JRE that's also
installed on my system?
The hack I use right now is to copy the (server) x64 "jre" subdirectory
inside the MAT directory - that seems to get picked up. However, I
assume there's an easier and cleaner way?
-tt
Re: Configuring JRE for running MAT [message #5447 is a reply to message #5441] Wed, 15 October 2008 08:58 Go to previous messageGo to next message
Try running
MemoryAnalyzer.exe -vm <path_to_jdk>\bin
pay attention you have to give it thepath down to the bin folder.
Let me know if this helps.
regards,
Krum
Re: Configuring JRE for running MAT [message #5489 is a reply to message #5447] Fri, 17 October 2008 04:02 Go to previous message
Hi Krum,
Krum Tsvetkov wrote:
> Try running
Thanks, I've got it working.
Had to play for a few minutes with proper quoting.
This one works:
"C:\Program Files\<mat x64 dir>\MemoryAnalyzer.exe" -vm "C:\Program
Files\Java\jdk1.6.0_07_x64\bin"
This one doesn't:
"C:\Program Files\<mat x64 dir>\mat\MemoryAnalyzer.exe" "-vm C:\Program
Thanks for your help,
-tt
Previous Topic:Help understanding a heap dump
Next Topic:Using pre-indexed dump
Current Time: Mon Sep 22 21:34:11 EDT 2025
Powered by FUDForum. Page generated in 0.25579 seconds
