Re: is sharing the mylyn DB folder between eclipse instances ok? [message #599886 is a reply to message #599881] |
Fri, 30 October 2009 18:28 |
Peter Stibrany Messages: 37 Registered: July 2009 |
Member |
Simple solution is to subscribe for some free repository service :-)
For example, hosted FogBugz repository is free for 2 users
(http://www.fogcreek.com/FogBugz/StudentAndStartup.html), and Foglyn,
FogBugz connector for Mylyn, can also be used for free for this FogBugz
edition (http://www.foglyn.com/fogbugz-startups-students.html).
I think it is also possible to find free Trac hosting or some other
repository which will suit your needs.
-Peter
Jason wrote:
> I encounter the similar case.
> I use the Local repository and want to share this tasks and their
> context through different workspaces. These workspace has similar
> projects and codes, i.e, one for maintenance, the 2nd for development.
> Can we have there any options such as new Local repository in eclipse
> instance installation dir, or even to specify a dir, i.e, c:\myRepository
> At least, we should be able to export a task and its context and then
> import it into another local repository. Can't we do that?
> Thanks.
FUDForum. Page generated in 0.03534 seconds
