[Teneo] GMF -mindmap example problem [message #597005] |
Mon, 18 December 2006 16:05 |
Kirill A. Balod Messages: 30 Registered: July 2009 |
Member |
I have tried to repeat a tutorial which is described at
http://www.elver.org/hibernate/gmftutorial/tutorial1.html . And have got
"java.lang.IllegalStateException: Cannot modify resource set without a write
transaction" from the action "Initialize mindmap_diagram diagram file"
Any ideas?
Kirill
Exception:
transaction
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:295)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:257)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessResourceNotification(TransactionChangeRecorder.java:22 7)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:193)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:230)
at
org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1029)
at
org.eclipse.emf.teneo.resource.StoreResource.addToContent(St oreResource.java:284)
at
org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:269)
at
org.eclipse.emf.teneo.resource.StoreResource.getContents(Sto reResource.java:398)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.s etTarget(TransactionChangeRecorder.java:128)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.didAdd(BasicNotifierImpl.java:71)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:620)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 00)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:119)
at
org.eclipse.emf.ecore.change.util.ChangeRecorder.addAdapter( ChangeRecorder.java:697)
at
org.eclipse.emf.ecore.change.util.ChangeRecorder.notifyChang ed(ChangeRecorder.java:352)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:173)
at
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatc hNotification(NotifyingListImpl.java:260)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:292)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:411)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:233)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:384)
at
mindmap.diagram.part.MindmapInitDiagramFileAction.run(Mindma pInitDiagramFileAction.java:117)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
MindmapInitDiagramFileAction.java :
111 TransactionalEditingDomain editingDomain =
GMFEditingDomainFactory.INSTANCE
112 .createEditingDomain();
113 ResourceSet resourceSet = editingDomain.getResourceSet();
114
115 EObject diagramRoot = null;
116 try {
117 Resource resource = resourceSet.getResource(URI
118 .createPlatformResourceURI(mySelectedModelFile
119 .getFullPath().toString(), true), true);
120 diagramRoot = (EObject) resource.getContents().get(0);
Configuration:
emf-sdo-xsd-SDK-M200611161441.zip
emft-ocl-SDK-1.0.0.zip
emft-query-SDK-1.0.1.zip
emft-teneo-SDK-I200611290220.zip
emft-transaction-SDK-1.0.1.zip
emft-validation-SDK-1.0.1.zip
GEF-SDK-3.2.1.zip
GMF-sdk-experimental-N20061115.zip
GMF-sdk-N20061115.zip
hibernate-3.2.1.ga.zip
uml2-SDK-2.0.2.zip
FUDForum. Page generated in 0.03170 seconds
