| Copy and Paste with NumberFormatter [message #60202] |
Tue, 21 October 2008 13:42  |
I am trying to use NumberFormatter and DataBinding with a Text control.
When I insert some number with copy and paste, only the first digit
appears in the text control. When I change the verifyText method form
(line 637 ff)
int d = editValue.indexOf(EMPTY + symbols.getDecimalSeparator()); //
Decimal separator position
for (int i = 0; i < e.text.length(); i++) {
to
for (int i = 0; i < e.text.length(); i++){
int d = this.editValue.indexOf(EMPTY +
this.symbols.getDecimalSeparator());
it works. So I have two questions:
1. Does copy and paste work with NumberFormatter?
2a. If yes: Can you give mi some hint what to do?
Somebody can give me some help on this?
Thanks in advance.
Leo
| Re: Copy and Paste with NumberFormatter [message #61605 is a reply to message #60967] |
Wed, 07 January 2009 16:42  |
Seems you aren't the only ones with this problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248931
Eric seems to be slow at working on fixes, but nagging through bugzilla
is probably the best way to encourage him.
I have added your change as a patch on the bug, hopefully this will help.
- Andi
Andrzej Urban wrote:
> Leo Niedermeier wrote:
>> control. When I insert some number with copy and paste, only the first
>> digit appears in the text control. When I change the verifyText method
>> form (line 637 ff)
>> // Decimal separator position
>> to
>> Thanks in advance.
>> Leo
> I'm facing the same problem in my application.
> Did you manage to find the solution or the reason it behaves like that?
> I'm looking for the solution that does not involve changing the
> implementation of the NumberFormatter class.
> I'd be grateful for any tips
> Andrzej
| Re: Copy and Paste with NumberFormatter [message #592844 is a reply to message #60202] |
Mon, 08 December 2008 07:01  |
> (line 637 ff)
> to
> Thanks in advance.
> Leo
Andrzej
| Re: Copy and Paste with NumberFormatter [message #593129 is a reply to message #60967] |
- Andi
>> form (line 637 ff)
>> to
>> Thanks in advance.
>> Leo
> Andrzej
FUDForum. Page generated in 0.04837 seconds
