Home » Archived » Visual Editor (VE) » properties can be set but not shown after reload Visual Editor
properties can be set but not shown after reload Visual Editor [message #595098] Tue, 13 July 2004 11:57
Originally posted by: peter.villiger.gmx.ch
there are properties they can be set and shown correctly by property editor.
But after reopen the Visual Editor the property view doesn't show the
property value.
This happens to String property set by a constant and String[] property set
by constants.
aBean.setPropertyName(CONST_A);
aBean.setPropertyNames( new String[] {CONST_A,CONST_B} );
I this a bug which should be posted?
I use Eclipse 3.0, Visual Editor I20040706
Thanks and regards
peter
log:
!ENTRY org.eclipse.ve.java.core 2 0 Jul 13, 2004 17:45:04.522
!MESSAGE Exception thrown.
!STACK 0
java.lang.InstantiationException: IWAV0125E "new String[]{CONST_A, CONST_B}"
is too complicated to be evaluated
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.createBean
Proxy(REMStandardBeanProxyFactory.java:262)
org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstance(R
EMAbstractBeanTypeProxy.java:239)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.i nstantiateWithSt
ring(BasicAllocationProcesser.java:210)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAll
ocationProcesser.java:149)
ocationProcesser.java:120)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.beanProxy Allocation(BeanP
roxyAdapter.java:883)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(
BeanProxyAdapter.java:832)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(Bean
ProxyAdapter.java:762)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applied(B eanProxyAdapter.
java:257)
org.eclipse.ve.internal.jfc.core.ComponentProxyAdapter.appli ed(ComponentProx
yAdapter.java:166)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.appli ed(ContainerProx
yAdapter.java:57)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applyAllS ettings(BeanProx
yAdapter.java:544)
org.eclipse.ve.internal.jfc.core.ComponentProxyAdapter.apply AllSettings(Comp
onentProxyAdapter.java:635)
ProxyAdapter.java:764)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponentWithConst
raint(ContainerProxyAdapter.java:221)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponent(Containe
rProxyAdapter.java:189)
yAdapter.java:55)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.appliedLi st(BeanProxyAdap
ter.java:184)
yAdapter.java:540)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(Compos
itionProxyAdapter.java:143)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(Comp
ositionProxyAdapter.java:115)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1464)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Previous Topic:VE Bean JLabel generates another code as JCheckBox
Next Topic:Cannot control parent
Current Time: Sat Oct 25 18:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.04554 seconds
