CDateTime - setEditable/setEnabled [message #594940] |
Fri, 05 June 2009 07:42 |
Peter Pfeifer Messages: 98 Registered: July 2009 |
Member |
Hello.
It's me again. I just encountered an issue regarding
CDateTime.setEditable(false). If set to false, I'd expect the control to
behave like an ordinary text control does. It should be possible to
select the date copy it to the clipboard. Right now setEditable to
false, disables the possibilty to enter a date manually, BUT it's still
possible to drop down the datepicker or change the date by using the
arrow keys (up/down).
In my opinion setEditable to false should prevent the user from dropping
down the datepicker or changing the date via arrow keys. It should just
be possible to select the date and copy it to the clipboard as it's
established with a non editable text control.
More or less it should be the same as setEnabled to false except that
it's possible to traverse through the control and select its content.
Do you think that this is worth filing a bug entry?
Peter
FUDForum. Page generated in 0.02668 seconds
