Mylyn issues with respect to JBoss jira [message #594787] |
Wed, 12 November 2008 11:30 |
Max Rydahl Andersen Messages: 23 Registered: July 2009 |
It's been a while since I tried Mylyn so I wanted to put these questions
here before infecting bugzilla with them ;)
I'm trying out Mylyn's jira integration and got a few questions/issues.
1) When adding a Jira Apache and Codehaus is in the dropdown - how do we
get JBoss in there ? Which extension point should I implement (if any ;)
2) First time I setup to connect with JBoss it takes a *long* time (>1
minute) before it gets ready and show me the list of projects - what is
Mylyn doing here ? It must be more than just getting the list...maybe the
progress monitor be a bit more informative so I know *something* is
happening.
3) I would suggest you add a filter field for the project selection; that
would be usefull for jira's with alot of projects like jboss
4) Duplicate Detection - this is a very interesting feature ;)
If I want an alternative which extension points should I add ?
5) Duplicate Detection - Detector: Stack trace.
I tried this against JBoss jira but got an error dialog saying:
Result code 403: You are not allowed to get a result set of more than
100 results. Current search returns 2470 results
Looking at the full error message which includes the url it seems it is
set to 5000 (why that high of a number ? When is 5000 search
results relevant from jira ?).
I changed the limit to 100 and it started working. Maybe the ui should
suggest this in case of errors ?
Now when it is running it looks like it is searching across *all* of
JBoss org jira instead of limiting to that single project I
was asked to select in step #2. Why is that ?
Alot of these issues also don't seem to contain any references to the
exeption I pasted in - the jira search seem to be extremely
broad and not required to include the exception text.
Otherwise it looks like the jira adapter have greatly improved since the
last time I used it :)
/max
FUDForum. Page generated in 0.03755 seconds
