Open BPMN model in main method [message #593840] |
Thu, 20 September 2007 14:04 |
Originally posted by: anders.ottosson3.telia.com
Is there a way to open a bpmn-model in a standalone main method? Since
I'm a n00b at Eclipse BPMN/GMF/EMF I have tried the FAQ (from EMF)
examples with no luck, the result is always:
Exception in thread "main"
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'version'
not found. (file:/C:/src/test/BPMN/credit_report.bpmn, 2, 175)...
The code I have tried with is:
ResourceSet resourceSet = new ResourceSetImpl();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "bpmn",
new BpmnResourceFactoryImpl());
BpmnPackageImpl.eINSTANCE.eClass();
Resource resource = resourceSet.getResource(URI.createFileURI(fileName),
true);
try {
resource.load(null);
} catch (Exception e) {
e.printStackTrace();
I have added the following jars to the classpath:
org.eclipse.core.runtime_3.2.0.v20060603.jar
org.eclipse.emf.common_2.3.0.v200709042200.jar
org.eclipse.emf.ecore.change_2.3.0.v200709042200.jar
org.eclipse.emf.ecore.xmi_2.3.1.v200709042200.jar
org.eclipse.emf.ecore_2.3.1.v200709042200.jar
org.eclipse.stp.bpmn.diagram_1.0.0.061.jar
org.eclipse.stp.bpmn.edit_1.0.0.061.jar
org.eclipse.stp.bpmn_1.0.0.061.jar
Any help would be greatly appreciated!
Anders Ottosson
Re: Open BPMN model in main method [message #593884 is a reply to message #593840] |
Thu, 20 September 2007 15:06 |
Originally posted by: atoulme.intalio.com
Hi Anders,
off the top of my head, untested and all:
TransactionalEditingDomain domain =
GMFEditingDomainFactory.INSTANCE.createEditingDomain();
ResourceSet resourceSet = domain.getResourceSet();
Resource res =
resourceSet.getResource(URI.createPlatformURI(file.getFullPa th()), true);
and then you are done.
Couple of notes:
the URI and the path depend of your environement. The platform URI is
handy for things inside the workspace. You might have to do some
trial/error tests there.
Doing a getResource('', true) loads the resource. No need to load it
explicitly afterwards.
The domain takes care of the bpmn editing domain and will resolve the
model, as it is declared in the plugin.xml. No need to register it, I think.
I haven't touched that particular part of our code for some time, so
please proceed with caution :).
I hope this helps. Feel free to ask on the EMF newsgroup if that doesn't
work. Ed is always very helpful (and fast !).
Antoine
> true);
> try {
> Regards
> Anders Ottosson
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: Open BPMN model in main method [message #593905 is a reply to message #593884] |
Thu, 20 September 2007 20:01 |
Thanks for the answer, I will try this in the morning when my head
clears up a bit...
/Anders
Antoine Toulme wrote:
> Hi Anders,
> Resource res =
> Couple of notes:
> think.
> Antoine
>> Resource resource =
>> resourceSet.getResource(URI.createFileURI(fileName), true);
>> try {
>> Regards
>> Anders Ottosson
FUDForum. Page generated in 0.02860 seconds
