My Aspect is not run [message #593790] |
Tue, 23 May 2006 12:55 |
Jimisola Laursen Messages: 134 Registered: July 2009 |
Hi!
I believe that I have my pointcut and my only advice (TransactionAspect)
setup correct - no errors or warnings.
AJDT says "38 AspectJ markers at this line" on the line of my "around"
advice.
One method that this around advice should be applied to is Server.start.
If I look on the method signature line AJDT says "advised by
TransactionAspect.around(Transcational): TRANSACTIONAL.. (runtime test)".
I've added several break points, both in the actual code of the around
advice and in code in other classes that it calls, but none of the break
points are hit (yes, I am running the application in debug mode). I also do
debug outputs in the around advice both to stderr and to a logfile (using
log4j) - no output what so ever.
The odd thing is that when I hit a breakpoint in the method that the advice
is suppose to be applied on - Server.start - then I see the following in the
Debug Window:
Thread[main] (Suspended (breakpoint at line 285 in Server)
Server.start_aroundBody0(Server, Properties, JoinPoint) line: 285
Server.start(Properties) line: 1
Any idea on what my problem is. If you need the actual aspect to help me I
gladly provide it.
Jimisola
FUDForum. Page generated in 0.02622 seconds
