RCP Export Problems -- "Unable to acquire application service" [message #593677] |
Sat, 21 March 2009 18:37 |
Jesse Riggins Messages: 24 Registered: July 2009 |
--------------070809080608020406070802
(Apologies for the cross post...please let me know if this was better
suited in one newsgroup over another)
I was seeing this problem in a separate application that I was trying to
export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.
First off, I created the new app and a launch config using only those
plugins deemed required by the system. When I attempt to run, I get the
trace listed as "Trace 1" below. After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.
Next I created a product (HelloWorld.product) based off of the launch
config and tried to export it. Everything seems to export fine, but
when I run the eclipse.exe file, I get the "Trace 2" trace.
Would anyone have an idea as to whether or not there is something that
I'm doing wrong? I've got the sample app that I can send if need be.
Thanks in advance,
Jesse
*Trace 1:*
!SESSION 2009-03-21 12:14:23.437
eclipse.buildId=unknown
java.version=1.6.0_05
Framework arguments: -product HelloWorld.product
Command-line arguments: -product HelloWorld.product -data
C:\dev\ChiroPOS2/../runtime-HelloWorld.product -dev
file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.IllegalArgumentException: The System Bundle's start level can
not be modified.
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623)
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!MESSAGE
!STACK 0
not be modified.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Platform not running
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
Trace 2:
*!SESSION 2009-03-21 12:05:43.000
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
suited in one newsgroup over another)<br>
<br>
to export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.<br>
<br>
the trace listed as "Trace 1" below. After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.<br>
<br>
when I run the eclipse.exe file, I get the "Trace 2" trace.<br>
<br>
I'm doing wrong? I've got the sample app that I can send if need be.<br>
<br>
Thanks in advance,<br>
Jesse<br>
<br>
<b>Trace 1:</b><br>
<br>
-----------------------------------------------<br>
eclipse.buildId=unknown<br>
java.version=1.6.0_05<br>
java.vendor=Sun Microsystems Inc.<br>
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US<br>
Framework arguments: -product HelloWorld.product<br>
<a class="moz-txt-link-freetext" href=" file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties "> file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties </a>
-os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109<br>
!MESSAGE An unexpected runtime error has occurred.<br>
!STACK 0<br>
not be modified.<br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308) <br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234) <br>
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211) <br>
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469) <br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281) <br>
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247) <br>
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201) <br>
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644) <br>
at
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175) <br>
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br>
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br>
at java.lang.reflect.Method.invoke(Unknown Source)<br>
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) <br>
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)<br >
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)<br>
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)<br>
<br>
!MESSAGE <br>
!STACK 0<br>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125<br>
!MESSAGE Application error<br>
!STACK 1<br>
java.lang.IllegalStateException: Platform not running<br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) <br>
<br>
<br>
<br>
<b><br>
Trace 2:<br>
<br>
</b>!SESSION 2009-03-21 12:05:43.000
Command-line arguments: -os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781<br>
!STACK 1<br>
(see config.ini).<br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386) <br>
at
<br>
</body>
</html>
--------------070809080608020406070802--
FUDForum. Page generated in 0.03010 seconds
