Home » Eclipse Projects » DTP » drop schema lars; results in syntax error
drop schema lars; results in syntax error [message #587390] Sun, 19 August 2007 18:45
I have in Derby 10.2.2.0 a schema called "lars". This was created via the
SQL Editor and the following statement:
create schema lars;
I'm not able to delete this schema. If I type the following into the SQL
Editor:
drop schema lars;
The SQL Editor returns with an error message:
Syntax error: Encountered "<EOF>" at line 2, column 18.
Can you please check? I assume this is a bug and will open a bug report for
this if noone know a solution for this.
Best regards, Lars
Previous Topic:Editing Tables
Next Topic:Getting all jdbc connection info in a reliable way ?
Current Time: Fri Nov 07 19:18:56 EST 2025
Powered by FUDForum. Page generated in 0.02762 seconds
