Home » Eclipse Projects » Nebula » SWT Ribbon - Alpha 2 Out
SWT Ribbon - Alpha 2 Out [message #586733] Wed, 28 November 2007 16:05
Hello all!
Just doing a quick post to let you all know the SWT Ribbon is up/out as an
Alpha 2. I'm between things at the moment (moving to a new country among
other things - no I'm not running from anything ;-) ) so I figured I'd make
an update to it while I can and have internet. It should be quite a bit more
stable than the first Alpha and includes lots of fixes and new features (the
RibbonShell and the two-style toolbars among others), but there's still
stuff missing and so on.
For downloads, screenshots, what's left to do, etc, go to
http://www.hexapixel.com/ribbon/
You'll need Java 5, I don't really plan on making it 1.4 or earlier
compatible, 5.0 is just too convenient for maintaining large amounts of
code.
Please post questions/problems in this very thread and I'll check it when I
can. For example code, check the RibbonTester.java file in the source jar.
Kind of important note: It's not required you use the RibbonShell at all,
you can use it as a widget as well just like the older screenshots. The
sample code however uses the shell but there's commented out code that uses
it as a widget in the RibbonTester.java file as well.
Enjoy (I hope)!
Emil
Emil Crumhorn
Nebula Committer
Previous Topic:GridViewer and SWT.VIRTUAL
Next Topic:GridTableViewer - CellModifier problem with collapsed GridColumnGroup?
Current Time: Thu Oct 23 03:45:02 EDT 2025
Powered by FUDForum. Page generated in 0.02866 seconds
